This thread is privately moderated by jiggz, who may elect to delete unwanted replies.
Dec 08, 2017, 06:50 PM
"its not a hobby its obsession
jiggz's Avatar
Build Log
Park flyer plastics . Continental 4 cylinder dummy engine
After owning a 1/6 scale piper grasshopper for a while I have decided to do some scale work on it .
The park flyer plastics dummy 4 cylinder is a very close match for size on the Maxford grasshopper
I am planning on opening up the stock cowl to expose the dummy motor
The 4 cylinder has just enough space for my custom motor mount and my eflite power 25 (1000kv)inside .
http://parkflyerplastics.com/cart/in...roducts_id=635
Dec 08, 2017, 06:56 PM
jiggz's Avatar
Removing the cylinder parts
Making small circles adding pressure to the sides on worn 70grit glass paper .
The formed cylinders came away nicely .
I need to clean with 1000grit and separate the pairs
Dec 09, 2017, 08:18 AM
jiggz's Avatar
Removing the caps/crank casings/exhausts
All parts now removed and cleaned
Dec 09, 2017, 05:13 PM
jiggz's Avatar
Seperating the parts
I used a snap knife to split the cylinder pairs .
Cylinders are numbered to keep in there pairs
Crank cases were seperated by using the snap knife to score eventually cutting
Dec 10, 2017, 08:47 AM
jiggz's Avatar
Joining the crank cases
I want to enhance the build using screws ..I would like nuts and bolts ..but I can't find any small enough
I used some small plinths of ply to sit flush inside the cases between the moulded bolt points ..
I cut down some small screws and drilled the casing bolt mouldings and joined the two case halves .
At the moment its mocked up ..I will remove for painting and re place the screws to keep them silver so they stand out against the painted casings
Dec 11, 2017, 01:15 PM
jiggz's Avatar
Joining the cylinder halves
The cylinder halves were kept in there numbered pairs
The top section of moulding was removed with a snap knife and then the edges were cleaned by making circles on 1000grit paper until the two halves of each pair matched .
I used revell poly cement and applied a small line of bond on to a a scrap piece of plastic and then ran the cylinder half joining sides through the cement .. matched up and held in place with tamiya fine line mask
There are a few join lines that need a slight clean
Dec 11, 2017, 05:58 PM
jiggz's Avatar
Cleanimg the cylinder joins
Using a fine file with a sharp strait edge I rerun it over the top of the joins flat then used the edge to clean between the air cooling plates
All the join lines now match up quite nicely
Dec 13, 2017, 03:27 PM
jiggz's Avatar
Paint & push rods
I have painted the lower barrel tamiya semi gloss black the cylinder heads are tamiya flat ally
The crank case is tamiya neutral grey
I made up the pushrods with model kit sprue and then wrapped ally tape around them
Dec 14, 2017, 06:45 PM
RobDog's Avatar
Very nice!
Dec 14, 2017, 08:46 PM
Balsadustus Producerus
Remember, on Continental engines, the pushrods and tubes are below the cylinders. Lycomings are above. Just a heads-up.
Latest blog entry: Single Channel Case
Dec 15, 2017, 06:35 PM
jiggz's Avatar
Originally Posted by RobDog View Post
Very nice!
Cheers rob
Cheers for the head up balsa ..I am intending to put it upside down .
I did a little work to the upward side today
Regards
Jeff
Dec 15, 2017, 06:42 PM
jiggz's Avatar
Spark plugs / ht caps / leads / and hoses
I added some little made up spark plugs for the cylinder heads and added some leads
I need to weather them down a bit ..they are a little bright
I added the crank case hose and made up a little hose fitting
The loom bands around the barrels r temporary
Dec 21, 2017, 08:18 AM
circle flyer
slow and low's Avatar
Great job Jeff, looks fantastic
Larry
Dec 21, 2017, 08:24 AM
jiggz's Avatar
Cheers Larry .. I have taken a little break from this project whilst I deal with a few others ..
Next task is to add a dizzy and a few other ancillary parts
Im also going to make the air filter operational leading into the underside to help keep the motor cool ..it doesn't do to much hard work ..but just to be sure there's no overheating
Then I can fit it to the model and start on the cowl mods .. I need to separate the cowl into inspection panels and hinge..
Regards
Discussion Twin-engine 3D park flyer Andrey_Rakhmanov Foamies (Scratchbuilt) 2 Oct 03, 2017 01:31 PM
Build Log Park Flyer Plastics "1/4" Scale P-40 bwoollia Scale Kit/Scratch Built 419 Aug 30, 2017 05:37 PM
Data Wiring Diagrams for Multi-Engine PARK FLYER Electrics P. Tritle Scale Kit/Scratch Built 39 Jan 26, 2017 04:30 PM
Discussion Looking for a park flyer 4/ channel low wing to build.. agentorange90 Foamies (Scratchbuilt) 1 Sep 19, 2015 10:05 AM
New Product O. S. Engines Il-300 Dia-star 4-cylinder 4-stroke Inline Engine Jim T. Graham Product Announcements 0 Dec 26, 2006 04:06 PM
