OS 75AX Engine - Just Broken In - Free Shipping - RC Groups
This thread is privately moderated by patniven, who may elect to delete unwanted replies.
Dec 07, 2017, 06:20 PM
Trader Rating: 24
Gus Grissom: "F***in-A bubba!"
patniven's Avatar
$150.00 USD
Seller Pays Shipping
Sold
This OS 75AX engine has been properly broken-in, and has had 10 tanks run through it. It starts on the first flip every time, idles perfectly and has a crisp throttle response. The engine's condition is flawless, not even a fuel stain.
From the Manufacturer:
The power source for 60-sized aircraft.
Power up your big bird the easy way: simply swap out your 61FX with the awesome 75AX ABL! It uses the same mount and fits the exact same bolt pattern, so there’s no modifications required. The angular head not only looks sharp, it also significantly increases surface area for better cooling. A diagonally positioned needle eliminates the need for a remote needle valve. Plus, you get a Power Box muffler that's small in size, but robust in volume.
- Fits the same mount and bolt pattern as the 61FX.
- The angular head design looks great and significantly increases surface area for better cooling.
- Includes a Power Box muffler, designed with more volume for increased power while still being very compact.
- A diagonally-placed needle means no remote needle valve is needed.
Sells new for $249: https://www.towerhobbies.com/cgi-bin...&I=LXRPD2&P=ML
Sold OS Engines New in Box(never mounted or ran) FREE SHIPPING barrethoke Aircraft - Fuel - Engines and Accessories (FS/W) 11 Aug 11, 2016 09:11 PM
Sold Made in Japan Os 75AX with OS Max Factory Motor Mount Whitman Flyers Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 21, 2016 10:11 PM
For Sale NEW IN BOX,free shipping, OS ENGINE Turqui Aircraft - Fuel - Helis (FS/W) 0 Nov 09, 2015 10:49 AM
Sold OS FS-52S Four stoke engine. Used in great condition. Free shipping SlickZERO Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 30, 2015 04:27 PM
Sold Just Broken-in O.S. .75AX w/mounts For Sale Talldog Aircraft - General - Miscellaneous (FS/W) 1 Jan 17, 2015 12:11 PM
