This thread is privately moderated by decuzar, who may elect to delete unwanted replies.
Dec 07, 2017, 02:43 PM
US ARMY retired
decuzar's Avatar
3DHS 79" slick "Lite"
Okay so Im attempting to build a 3DHS 79" slick 580 very lite, my goal is for the plane to come in at 13lbs wet, I will document my progress along the way, Im not fast so this may take a few months...........
STOCK SPECs
Specifications
Wingspan: 79 inches
Length: 77 inches
Wing area: 1167 square inches
Weight: 14-15.5 lbs.
Firewall to back of spinner: 6.5 inches
Gas Power System
50CC-55CC single cylinder gas
12-17 oz. fuel tank
22 x 8 gas prop
Dec 09, 2017, 11:20 PM
US ARMY retired
decuzar's Avatar
Since I will be using a smaller motor than normal (vvrc 40 gen II) and since I like useing my rudder servo in a push pull configuration I will need to do some work on the rear of the plane, one of the first things is to lighten my elevator control arms, the stock arm came in at 22.4 grams so I took some carbon fiber rod drilled out the ball links to fit the rod, epoxied them and drilled through the link and pinned them, I believe these will be as strong as the steel and more than half the weight off at 10 grams......
Dec 10, 2017, 12:25 PM
US ARMY retired
decuzar's Avatar
I think evrybody loves a removable rudder by just removeing a steel rod, so I thought that is a good place for a carbon fiber rod, and I had an old control rod for a Blade 400 that fit perfect, fitts nice and tight, stock rod is 10.8 grams new carbon rod is 1.4 grams AWSUM..........
Discussion Extreme Flight - 3DHS 79" Slick 580 blucor basher 3D Flying 2007 Nov 28, 2018 11:09 PM
Question 3dhs Slick 79" out of stock? stevenewald Electric Plane Talk 1 May 24, 2017 02:37 PM
Question 3DHS 79" Slick Battery Question with Optima 9 AgentJohnson Giant Scale Airplanes 5 Jan 10, 2017 08:08 PM
Discussion 3DHS 79 Slick Electronics AgentJohnson 3D Flying 24 Jan 09, 2017 09:43 PM
Discussion 79" Slick 580 BenBen123 3D Flying 2 May 16, 2016 10:12 PM
