Futaba 14SG Gimbals and RSSI - RC Groups
Dec 07, 2017, 01:56 PM
I can drift a heli
maarset's Avatar
Question
I have a couple questions about my Futaba.
I got the 14SG when I was into 3D heli's. Solid Radio Link. I used the 14SG for quadcopters for a while
but went to a Taranis for the telemetry. Futaba sbus2 RX's (telemetry) were kind of pricey.
Now with the newest flight controllers (BetaFlight) with the built in OSD I can get all the telemetry info on screen so in theory
I could use regular futaba Sbus RX's and not have to worry about telemetry going to the RX.
But my cyclic gimbal on the 14SG is getting a little sloppy and I have not been able to find replacement gimbals for it.
Do you have to send it in to Futaba to replace the gimbals?
Also I have been searching on how to get RSSI values from a futaba RX and I have a feeling it is not possible. Atleast for sbus right?
I have had good luck with frsky futaba compatible RX's and there is one that has a RSSI port but not sure if I could get that value to
my OSD which is built into the Flight Controller.
Dec 07, 2017, 01:58 PM
Sagitta Fanboy
There is no way on Futaba to map a telemetry value to a channel (which would be necessary to get RSSI on SBus).
You can use the FrSky TX with its RSSI port if your FC has an option for an external RSSI input.
Dec 07, 2017, 02:22 PM
I can drift a heli
maarset's Avatar
Thanks.
Yah it is super easy to map RSSI to a channel on my Taranis and then have it shown in the OSD which I do now.
Dec 07, 2017, 02:24 PM
I can drift a heli
maarset's Avatar
I found this frsky sbus rx which is futaba compatible and has a RSSI port.
https://alofthobbies.com/frsky-tfr8s...r-w-s-bus.html
Dec 10, 2017, 06:07 PM
RC expert
You could still use the Futaba RX, and use this small device which I designed In fact there is some RSSI (FER) information presented by default on the SBUS2 stream
http://shop.tje.dk/catalog/advanced_...?keywords=rssi
Discussion Futaba 14sg smooth gimbal tilt switch for DJI Phantom 2 nategreat Radios 1 Aug 15, 2014 10:02 PM
Help! Should rudder control on Futaba 14sg cause the gimbal to move? nategreat Multirotor Drone Talk 2 Aug 10, 2014 10:43 PM
Help! Any way to use external sticks with Futaba 14SG for pan/tilt gimbal control? Hogster Radios 1 Mar 05, 2014 12:05 PM
Discussion Step by step Futaba 14SG + Tarot T2D Gimbal TILT-ROLL-CENTER The Dragon Flyer FPV Equipment 0 Dec 20, 2013 12:15 PM
Discussion Step by step Futaba 14SG + Tarot T2D Gimbal TILT-ROLL-CENTER The Dragon Flyer Multirotor Drone Electronics 0 Dec 20, 2013 12:12 PM
