FAQ
Spektrum iX12
For all of your curiosities and questions to the iX12, join in the discussion!
TAP INTO THE POWER The iX12 brings Spektrum™ AirWare™ software and DSMX® technology together with smart features like an Android-powered touchscreen, WiFi connectivity and more. The result is a remarkable transmitter that is easy enough for sport pilots to use yet capable enough for expert RC competitors. https://www.horizonhobby.com/product...eiver-spm12000 https://www.horizonhobby.com/product...only-spmr12000 https://www.spektrumrc.com/Products/...rodID=SPM12000 |
Reason: Title Change
Some helpful tips:
SpektrumRC Instructional Video Series. https://www.youtube.com/playlist?lis...xymm-3LiI-P5dj What to expect when booting up. Android will take approx. 60 secs, then a 30 sec pause, then Airware will load, a beep will be heard when done.
Saving to SD Card: Tap export in model utilities Select the model to export Touch export Tap ES save to Choose path touch back arrow until you see /storage/extst Tap /storage/extsd Tap select Powering off or sleeping the screen: Pressing the Power button once will put the display to sleep but the radio will continue to transmit normally. Press the power button again to wake up the screen. Double pressing the Power button will open a window allowing you to select RF On/Off, LCD On/Off, or press and hold to put both RF and LCD into sleep mode. It is recommended you use the sleep mode rather than turning the system Off on flying days. To clear timers: Press and hold the timer. SD CARD: When removing the SD card, first go into settings and UNMOUNT it. Charging: The RF light will blink the entire time through the charge. Once it is complete, it will light solid. VOICE, see post https://www.rcgroups.com/forums/show...postcount=2511 Optional ways of moving files or images to the iX12 internal storage Remember to first unmount the SD card in settings, before removing it from the ix12 as well as to remember to eject the card via your computer, before removing it. Once the card is in the iX12: 1. Tap on ES File explorer 2. Swipe left twice, then tap on EXTSD 3. Tap on the folder the images are stored in. 4. Long Press on the image you want moved... a menu on the right will pop up, tap MORE 5. Tap MOVE TO and select the folder you wish to move the image to. This whole process might be a bit easier if you just hook the iX12 to your computer with the USB Cable. (no need to keep removing the SD card) ((make sure the iX12 is powered on)) 1. After connecting the iX12 with the USB cable to your PC, and it has "setup",,, you will need to navigate to the iX12 in your PC. 2. once there, click on iX12 and then a window with the Internal Storage and SD card will appear. Click on Internal Storage. 3. From there, you can directly add photos to the appropriate folder. (DCIM) 4. When done, eject the iX12 before you unplug from the PC. Downloading and importing model setups using only the iX12 and WiFi. 1. Using Google Chrome, navigate to www.spektrumrc.com , then to model setups, then ( I used the DX9 files as need to be Gen2 files) 2. Find the appropriate model file and tap it. (tip- either use your fingers and zoom in on the area of the page you want, or use a stylus) 3. once downloaded, tap the square in Android, then tap the X on Chrome to close it, then tap the header of the Airware app to bring it back to full screen. 4. Follow the normal steps to creating a new model, but instead tap the three dots at upper right, and then tap import, this then brings up a window. From there you need to tap the arrow in the upper left, ONCE, then tap on SD0 then tap on Downloads, then finally tap the file you want to import. Follow the remaining prompt(s) to finish. Easy file/photo transfer between a Mac and iX12 via USB See post https://www.rcgroups.com/forums/show...postcount=3504 Overly detailed instructions for using TeamViewer to work your ix12 from a PC See post https://www.rcgroups.com/forums/show...postcount=3601 Periodic reports from telemetry. Originally Posted by duworm Model Setup Audio events Custom reports Touch + symbol Touch > symbol Select switch Select frequency touch Pen Icon type "receiver voltage" followed by a space Tap Macros Tap QOS Tap Rx voltage Optimizing Boot Loop issue: For a possible fix, see this post. https://www.rcgroups.com/forums/show...postcount=3123 To reboot/restore using ADB tools See post https://www.rcgroups.com/forums/show...postcount=3995 Alternate link for ADB tools, http://www.mediafire.com/file/ccnnv8...oot_v1.4.3.zip To enter SAFE MODE of Android: Press and hold the power button. When the Power Off/ Reboot window pops up, long press POWER OFF. This will open up a window to confirm you wish to boot to safe mode. This will allow you to clear cache or uninstall an app, IF your radio is not booting properly. |
A few quick thoughts.
1. Overall, this is a game changer. It's the first radio release since the original Taranis X9D that I can really say that about. This will be extremely popular with the multirotor community in particular, as the ability to run a full android app for programming instead of a basic Lua script or 9x12 text box via SRXL changes the world there. 2. Spektrum REALLY needs to up its app game. The history of their programming apps is quite poor. That cannot continue. 3. Can we sideload? Either way, there needs to be a published, supported API for interacting with the telemetry system (for 3rd party telemetry apps) and with the external serial port. 4. That serial port? Can I or someone else write a custom protocol handler with telemetry support? If so, FrSky needs to get XST and R9S modules out with serial link support, because this just put the hurt on the Horus X10, especially in the multirotor community. 5. Custom caller apps. I've seen some pretty cool IMAC callers, and also guys running sailplane competition audio tracks on OpenTX. It's now totally doable on Spektrum and needs to happen. 6. Any stick/knob to Android inputs? Can I write something that pushes the input of an arbitrary switch/knob out via SRXL telemetry or even a channel? Can I write an app that communicates with an arbitrary device on the aircraft via the telemetry channel? So much possibility there, especially for things like GPS Racing. 7. Can I get the Airware App for other devices. As a guy who provides a fair bit of assistance to other club members on programming, it would be amazing if I could have folks email me an SPM, open it up on my phone, fix any issues or add the bits wanted and email it back for use on the iX12 or G2 TX's. You've already written the app, now let us use it as a programming app on larger screen devices (as nice as that screen is, I'd rather work on a 5.5" or larger device when doing the programming) |
Yes, the Android system can be a very big thing for this radio. I like many thing about this system and hope that they will extend the mixers and other function compared to the older style airwave. If they create the room for custom sensors then it would be perfect for me.
With the memory being expandable via SD card, I think anything is possible. I think they have a system that they can truly build and grow on.
This looks good. I wonder about the touch screen though. As I scroll down pages on my phone I sometimes inadvertently activate something, that could be dangerous. Also I would like to see something other than black. DX12 would have been a good name, but I guess that designation may be history. I think X12 would have been nice, something about the i doesn't do it for me.
The spec for the telemetry data service will be published eventually. It'll be rather straightforward. You may not need it, though. I finally got telemetry reporting to work the way I want it to (I didn't code it, just wrote the spec for it). Quote:
However, it has support being developed now for multiple protocols, so it probably won't be an issue. Quote:
![]() It's a standard Android interface. The only physical button that connects to Android is the power button, and even that is done indirectly. The interface is purely event-driven, so events such as switch changes are reported to Android by our service, but the app is the consumer. I don't know if they will be making available those events on the service or not. It wouldn't surprise me. The telemetry channel is incoming data, so no, you can't send the airplane anything through telemetry. Don't feel bad - nobody can, not even us. There is one forward channel, and one return channel. Quote:
![]() Andy |
Spektrum page has been updated to the correct version.
Thread Tools | |
Similar Threads | |||||
Question | Do I need new binding plug for a new Spektrum AR6100 receiver? | motorator | Radios | 6 | Jun 01, 2019 01:27 PM |
Alert | New Spektrum vs. Align T-REX 150 DFC BNF | Eddiejon | Radios | 1 | Dec 17, 2015 02:33 PM |
Discussion | Spektrum DX7 new no E switch? | The Flying Pig | Radios | 7 | Sep 27, 2015 02:13 PM |
Discussion | Spektrum DX10t ! Spektrum's New Flagship! Tray-Style, High-End Radio!!!!!!!! | Vicarious | Radios | 12 | Aug 22, 2011 09:32 PM |
