E-flite Power 15 + E-flite 40A Pro ESC *PRICE DROP* - RC Groups
This thread is privately moderated by ppalumbo, who may elect to delete unwanted replies.
Dec 06, 2017, 10:20 PM
Trader Rating: 0
$65.00 USD
Buyer pays shipping
Sold
E-flite Power 15 BL Outrunner 950kV + E-flite 40-Amp Pro Switch-Mode Bec Brushless ESC
**PRICE DROP**
$75$65 + Shipping
Power 15 Info:
  • Equivalent to a 15-size glow engine for sport and scale airplanes weighing 36- to 56-ounces (1020- to 1590-grams)
  • Ideal for size 3D airplanes 32- to 40-ounces (910- to 1135-gram)
  • Ideal for models requiring up to 425 watts of power
  • High torque, direct drive alternative to inrunner brushless motors
  • Includes mount, prop adapters, and mounting hardware
  • Quiet, lightweight operation
  • External rotor design, 5mm shaft can easily be reversed for alternative motor installations
  • High quality construction with ball bearings and hardened steel shaft
  • Slotted 12-pole outrunner design
The Power 15 is designed to deliver clean and quiet power for 15-size sport and scale airplanes weighing 36- to 56-ounces (1020- to 1590-grams), 3D airplanes 32- to 40-ounces (910- to 1135-gram), or models requiring up to 425 watts of power
40-Amp Pro ESC Info:
  • Up to 40 amps continuous current with proper air flow and 55 amps burst current (15 seconds)
  • 5A continuous current, 5V Switch-Mode BEC Circuit (Proper cooling and airflow required)
  • Stronger BEC for support of most 3-axis stabilization systems
  • Drive up to 7 analog or 6 digital standard-sized servos with the BEC
  • 3- to 6-cell Li-Po, 9- to 18-cell Ni-MH/Ni-Cd input voltage
  • Finned heat sinks
  • Programmable motor braking
  • Safe power-arm mode prevents accidental starts
  • Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V) or 70% of battery starting voltage
  • Programmable throttle input range
  • Programmable soft start for helis and airplanes
  • Auto motor shut down if signal is lost or there is interference
  • Programmable timing—5 user-selectable ranges to use with a large variety of brushless motors
  • Utilizes new smaller Mosfet technology to minimize weight
  • Radio System Power ON /OFF Switch
  • Prewired connector on battery input and 3.5mm gold bullet connectors on motor output leads
Dec 07, 2017, 08:08 PM
Trader Rating: 0
**PRICE DROP** now $65
Sold E-Flite BL-15 and 40A ESC jimbo12 Aircraft - Electric - Power Systems (FS/W) 0 Jul 05, 2017 10:53 PM
For Sale Two E-Flite Delta-V 15 EDF w/ 3200kv motors; Delta-V 480 EDF; E-Flite 60A & 40A ESCs jgalexander Aircraft - Electric - Power Systems (FS/W) 0 Jul 13, 2013 05:15 AM
For Sale E-Flite Delta-V 15 w/ 3200kv motor & E-Flite 60A ESC & E-Flite 40A ESC jgalexander Aircraft - Electric - Power Systems (FS/W) 3 Jul 12, 2013 11:06 PM
Sold E-Flite Delta-V 15 w/ 3200kv motor & E-Flite 60A ESC & E-Flite 40A ESC jgalexander Aircraft - Electric - Jets (FS/W) 0 Jul 04, 2013 08:05 PM
Sold E-Flite Power 10 & 40A Pro ESC icefog Aircraft - Electric - Power Systems (FS/W) 6 Aug 05, 2010 12:27 AM
