Hacker Model Super Decathlon 60 Electro EP ARF - RC Groups
A new Super Decathlon from Hacker Model is available, and ships from Tower Hobbies. This 80" balsa ARF is designed for electric power and builds quickly.
Available From Tower Hobbies
Hacker Model is now offering up a scale rendition of the famous Super Decathlon with a 79.5" wingspan. Designed for electric power from a RimFire .80 50-55-500, this 60-sized balsa and ply ARF can be flown with a 5-6S LiPo with at least 4000mAh, and a 90-amp ESC. Here's what Tower Hobbies says about the Hacker Model Super Decathlon 60 Electro EP ARF:
This semi-scale aerobatic plane is based on the well-known Bellanca Super Decathlon recreational aircraft and built from balsa and ply. Perfect for intermediate to advanced pilots and perfectly suited to glider towing, this isn't a plane you want to pass up! A NACA 2412 wing profile that's light and aerodynamic provides excellent lift and handling characteristics while the quality heat-shrink covering gives it a truly sublime look. Add in your choice of power system and take on the sky!
Features:
  • Construction: Balsa and ply
  • Cowl: Painted fiberglass
  • Wing: NACA 2412 wing profile, two piece with struts, dual servo aileron and flap control, vacuum formed plastic wing tips
  • Landing Gear: Main, one-piece aluminum, prebent wire tail gear, wheel pants,
  • 3.5" (90mm) diameter main wheels, 1.5" (38mm) tail wheel
  • Windshield: Clear molded plastic
  • Motor Mount: Plywood
  • Length: 53.1" (1350mm)
  • Wingspan 79.5" (2020mm)
  • Weight: 8.7lbs (3950g)
CLICK HERE for more info on the Hacker Model Super Decathlon 60 Electro EP ARF
Hacker Model Bellanca Super Decathlon 60 Electro EP ARF (6 min 43 sec)
Dec 06, 2017, 02:01 PM
AeroDan
Beautiful Model!!!! Always loved Citabrias/Decathlon’s.
Dec 09, 2017, 06:56 AM
RC addict since 1974
FlyBigElectric's Avatar
Anyone else look at the price yet?
Dec 11, 2017, 02:39 PM
DFS#000178
Rampage's Avatar
Yeah I noticed that too. I guess it's not absolutely terrible when you compare it to something like a TopFlite Cessna 182, being $110 cheaper, but it still seems like an enormous amount of money for a stand-off scale plane.
You can get a Carbon Z Cessna 150, with all the electronics, including the receiver, for $10.00 more. Sure, it's foam, but it flies so good. You'd have to throw probably another $250 (or a lot more with recommended electronics) at this one to have it flying if you don't already have the electronics, and I honestly just don't see the value in it.
If it were PNP at this price then hell yes, absolutely..
Question Phoenix Model Shoestring .46-.55 GP/EP ARF 60.4" jobinseattle Electric Plane Talk 17 Jun 14, 2017 07:40 PM
Discussion Phoenix Model Super Cub PA-18 30cc GP/EP ARF 107" Cyjonz Giant Scale Airplanes 29 May 22, 2016 01:17 PM
Question DECATHLON GP/EP Size .46-.55 SCALE 1:6 ARF stratoblaster Fuel Plane Talk 4 Mar 15, 2016 04:40 PM
Question Hacker Super Decathlon ARF: How to find? Where to buy? Fractal Parkflyers 1 Oct 01, 2015 08:00 AM
Discussion Phoenix Models Super Decathlon ARF .46-.51,66" rc_man1 Glow to Electric Conversions 10 Jun 15, 2013 02:25 AM
