Dec 06, 2017, 10:29 AM
InvertedCrab's Avatar
Question
Acro Wot XL - Electric Conversion?
Has anyone here converted an Acro Wot XL - ARTF to electric propulsion?
Already got a load of 6s 5000mah batteries but not sure if that will give it enough power.
If so, what setup did you use and were there any issues?
Did you make a battery hatch from the canopy?
Dec 06, 2017, 04:52 PM
I haven't done the Acro Wot XL, but just to get the ball rolling I converted my Xtra Wot from glow to electric. I use two 6S 3300 batteries in series to give 12S, a Hyperion ZS-4045/12 motor with 16x10 APC E prop giving just over 2,000 watts. Much better performance then when it was flying with an OS120AX glow engine.
You could use a single 6S pack if you can find a motor that will handle more amps than the 45A that mine draws at WOT.
I made my battery hatch by cutting out the decking on top of where the fuel tank goes in the glow configuration.
Dec 07, 2017, 11:50 AM
Thanks for the info abenn, that is very useful as the Xtra Wot is only 20cm smaller than the AcroWot XL.
Question Acro Wot XL - Electric Conversion? InvertedCrab Electric Plane Talk 2 Dec 06, 2017 10:28 AM
Discussion Acro Wot XL Acro29 Electric Plane Talk 1 Aug 19, 2017 03:21 PM
Discussion Acro-Wot Mk2 XL with DLE- 35RA Homesick Angel Engines 5 Apr 18, 2016 09:23 AM
Discussion Acro wot artf to electric theheed Glow to Electric Conversions 0 Nov 21, 2012 02:02 PM
