This thread is privately moderated by yosemitez, who may elect to delete unwanted replies.
Dec 05, 2017, 07:07 PM
yosemitez's Avatar
TBS Crossfire Link Quality (LQ) Taranis Call Out Warnings
A how to on youtube
First up why LQ and not RSSI, well LQ is Link Quality and it gives you a better representation of the RC link than the RSSI (received signal strength indicator) RSSI values don't take noise floor into consideration so you've never really got an accurate measure of your link by just looking at RSSI
RQly is the Link Quality value
RFMD is the crossfire link mode
0 = 4Hz
1 = 50Hz
2 = 150Hz
When RFMD in in 150Hz mode (2) LQ does not matter and does not need to be monitored.
Logical Switches:
L01: Monitors the Crossfire frequency mode, it then activates when RFMD is NOT in 150Hz mode
L02: Active when LQ is less than 80% and not in RFMD 2 mode, (a pre warning)
L03: Same as L02 but with the critical warning level at 70%
70% is considered the critical level for LQ
The 0.5 is a delay so that you not getting warnings when you get a quick drop in RF
Special Functions:
This does the actual call out to the speaker
SF01 will play sound "RF Low"
SF02 will play sound "RF critical"
The !1x means it wont play at startup
Check your LQ indicator ("Link Quality") to assess your link's health in regards to closeby external interference. The LQ goes from 0% (no signal) to 100% (full signal). Any value above 80% can be considered safe to fly, large drops below that indicates you are reaching the limits of your radio link. Also check your SNR indicator ("Signal to Noise Ratio") for your margin above the noise floor (far away external interference). The CROSSFIRE's LQ will deteriorate once the SNR reaches 0. Anything above 3 is good. The theoretical limit is -6dB. The RSSI indicates the signal strength of the antenna on the frequency that it is listening on. A high RSSI and low LQ indicates high interference, a high RSSI with high LQ indicates very good noise conditions. The RSSI goes from +10 to -130, in a logarithmic scale, with every further 6dB reduction indicating a doubling of your existing range.
https://www.youtube.com/watch?time_c...&v=-evvSJBAe8I
Jan 05, 2018, 05:44 PM
Thanks for writing this down!
Feb 17, 2018, 03:13 PM
Any info on when to use Link Mode 1 or 0? Mine is defaulting to 2 (150Hz) so I don't suppose I'll be getting warnings from LQ.
Feb 19, 2018, 09:55 AM
It switches automatically as the link quality deteriorates. You shouldn't therefore ever need to alert when running 150hz (which is what L01 enforces in the example above).
Feb 25, 2018, 06:41 AM
because rust never sleeps....
HugoRogers's Avatar
Mar 04, 2018, 02:20 AM
Fantastic, thanks for the info. I had just been looking for a way to callout rssi, now I get why LA can be better.
Mini-HowTo Vector RSSI/LQ and Telemetry on the TBS Crossfire billpa Eagle Tree Systems 251 Mar 19, 2019 07:21 PM
Question 30 second call out on timer Taranis William Bosco Radios 1 Jun 04, 2017 03:46 AM
Discussion Taranis and TBS crossfire and CRSF protocol dk10438 Radios 0 Nov 07, 2016 12:56 PM
Discussion Latency between Futaba 14SG, Spectrum DX9, Frsky Taranis, and TBS Crossfire mark97564 Multirotor Drone Talk 0 Sep 16, 2016 03:51 PM
Discussion frsky Taranis X9e with TBS Crossfire? help... v8r Radios 1 May 19, 2016 08:37 PM
