Dec 05, 2017, 02:21 PM
New Product
Meet BrainFPV radix
BrainFPV is excited to finally introduce radix, the most innovative line of drone electronics ever made. It is an evolution of the BrainFPV RE1 - our legendary flight controller released in 2016, which is still the only Betaflight flight controller with a full-graphic OSD and was the first flight controller to implement innovative features like SmartAudio video transmitter configuration.
What makes radix the best flight controller?
  • Improved form factor for easier soldering of PDB / 4-in-1 ESC underneath RADIX FC
  • Plug-and-play stacking on RADIX PB or Hobbywing 4-in-1 ESC using soft cables for vibration isolation
  • Graphical OSD - the only flight controller running BF with this feature
  • Customizable OSD logos using the BrainFPV Logo Customizer
  • STM32 F4 processor running at 180MHz
  • Better sensors - Bosch BMI160 gyro, proven on RE1 (pilots are raving about it)
  • Integrated barometer - so you always know how high you are
  • MicroSD card slot for logging
  • Integrated silicone grommets for vibration isolation
  • Dedicated camera control pad for changing camera settings
  • Dedicated RGB LED output for programmable LEDs
  • Four full hardware serial ports (UARTs) - two of them have signal inverters that are automatically enabled or disabled, so they can be used with S.Bus or SmartPort
  • 6 motor outputs with support for DHSOT (150/300/600/1200) and OneShot
  • Up to 8S and 160A support with the radix pb
  • radix pb features 5V (2A) regulator, current and voltage sensing
  • radix pb has 4 integrated programmable RGB LEDs - show your color
  • ESC signal and telemetry wires are soldered to radix pb for cleaner / simpler wiring
  • IR Lap timing with support for I-Lap and Trackmate (needs external IR LED and driver)
  • Supports Betaflight
  • Engineered and tested in the USA
For more information check out the webpage at https://www.brainfpv.com/radix/
Price: $49.99 for radix fc, $19.99 for radix pb. Preorders start Friday December 8, 2017
Dec 05, 2017, 02:57 PM
Woga65's Avatar
Supports dRonin like the RE1?
Dec 05, 2017, 05:01 PM
We currently don't plan to officially support it, i.e., support could be added to dRonin but it would have to be maintained by the dRonin project.
Jan 03, 2018, 11:56 AM
compass
Is ther a way to connect an external compass like a SDA and SCL pad?
Jan 03, 2018, 01:19 PM
No, unfortunately it doesn't have external I2C
Jan 03, 2018, 09:07 PM
First time drone builder...
I want to make sure I need the radix, the pb, and the 4 in 1 ESC together and is there a wiring diagram?
Jan 04, 2018, 09:38 AM
Not yet.. I'm about to get started making one .
With the radix fc, you either use the pb OR the 4-in-1 ESC. The wiring is quite simple, i.e., receiver and FPV camera are connected to the radix fc.
With the radix pb, you connect the battery and all the ESC's and their signal / telemetry wires to the radix pb and use the included cable to connect the radix pb to the radix fc.
With the 4-in-1 ESC, you just connect the battery and motors to the 4-in-1 ESC and connect the 4-in-1 ESC to the radix fc using the included cable.
Hopefully this will all make much more sense when the diagrams are ready
Jan 04, 2018, 11:58 AM
Oh thats a shame. i thought this would be the FC for my next build but without an I2C outbrake i might have to choose another one...
Is there maybe a way to solder directly on one of the legs of the chip?
Jan 04, 2018, 06:07 PM
No, the pins that could be used for I2C are unfortunately used for other functions
Jan 04, 2018, 08:38 PM
Thank you for the information... I thought that was the case, but I started second guessing.
I have some time before I do my first build. I need to try my Falcore out first (arrives tomorrow).
CRS
Jan 04, 2018, 09:18 PM
What needs to be updated when I get my Falcore...
Controller firmware
Prosight firmware
Anything else?
Jan 05, 2018, 05:27 AM
Okey, thanks for the information ansd the quick answer!
Jan 05, 2018, 05:40 AM
Sam Richard's Avatar
for GPS/MAG option .... you can use the DJI GPS style ones ...
Jan 05, 2018, 06:14 AM
They dont need an I2C bus to connect to? Only a UART for the GPS and the MAG?
Jan 05, 2018, 06:42 AM
correct ...
you can take a look into the I-Nav Wiki ...
New Product BrainFPV RE1: Next gen racing flight controller with OSD, Lap timing, LEDs & more HeliShredder Multirotor Drone Electronics 796 Jun 02, 2021 06:00 AM
Mini-Review BrainFPV RE1 and mPB combo thatjoshguy Multirotor Drone Electronics 0 Jul 18, 2016 06:04 PM
Contest BrainFPV Survey: Enter drawing to win a RE1! HeliShredder Multirotor Drone Electronics 1 Mar 12, 2016 01:31 PM
Discussion BrainFPV Flight Controller bearwolf50 Multirotor Drone Electronics 3 Apr 07, 2015 05:26 PM
Discussion BrainFPV, GPS FPV setup bradenr FPV Equipment 5 Jan 25, 2015 09:26 PM
