This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Dec 05, 2017, 12:29 AM
old4570's Avatar
Mini-Review
New iRangeX IRX4+ ( plus ) PPM mode
9x and the iRangeX IRX4 plus module bound to my JJRC H36 (2 min 30 sec)
Must be a real Bear for folks that dont want to run Open Tx , flash their firmware , or learn something new just to have fun !
Well iRangeX has brought out the IRX4+ ( plus ) which allows folks to just run PPM output and manually select the protocol from the back of the module .
Both my 9XR and 9XR pro have been flashed with firmware that allow the use of the older IRX4 module .
So the only Transmitter I had lying around gathering dust ( literally ) was my older Flysky 9x . Now the original module did not fit the 9x due to the design of the IRX4 case around the pins .. This has been corrected with the IRX4+ and I am happy to say the new IRX4+ fits in the back of my 9x perfectly .
To use the new IRX4+ one merely needs to chose PPM for the output , pop in the module and chose the protocol to run ..
From 1 to 15 there is no green light . From 16 - 31 you need to activate the green light .
Activating ( de ) the green light .
Push down the bind button , turn on the transmitter , hold the bind button for about 3 seconds - green light comes on .. Now you can select a protocol from the 16 - 31 range .
The JJRC H36 uses protocol 16 and binds automatically when the transmitter is turned on .
To turn off the green light = Push the bind button and turn on the Tx holding the bind button for about 3 seconds .
You need to be out off the green mode to chose between serial mode and PPM mode .. ( If you move the module from Tx to Tx as I have done )
So there you have it ! Now you can play with a multi protocol module and not have to change your Firmware . Just be aware there are fewer models to chose from in PPM mode ..
I purchased the IRX4+ from Banggood and FYI the price has just recently been lowered ...
I did not have to move channels around with the 9x , but I did have to reverse two channels . Also may I suggest activating throttle hold before playing .. So setting up the model was relatively easy compared to say Open Tx where usually I have to re assign channels when setting up a new model . I can see how this can be challenging and may take away from what should be a heap of fun ..
Well , now you have the IRX4+ to play with in PPM mode ..
Apr 08, 2018, 11:52 PM
marmalade1's Avatar
Any difference in range from internal to module RF unit?
I've only used my 4-in-1 for tiny models so far, but just installed an unused FlySky R6B into a small 1/2A plane. It will be odd to not have telemetry/ dual antennas again.
I converted to FrSky 3-4 years ago after my old FlySky tx lost 2 kit-built planes in 10 minutes. Since then I've had my 6 old FlySky R6B receivers laying around.
PD
Apr 09, 2018, 02:14 AM
old4570's Avatar
I am sorry , I dont know ..
This module is in my Taranis Q X7 99.99% of the time ...
I put it in the Flysky 9x to see if it would work in PPM mode .
So far I have had no range issues with the module in my Taranis , if anything it has range tested rather well . ( DSM2 receivers )
Oct 21, 2018, 11:46 AM
When I bind this to a JJRC H36 the blades run full speed. Sticks seem to make no difference.
Oct 21, 2018, 08:00 PM
old4570's Avatar
Interesting ...
Make sure your channels are correctly configured ..
AETR
Enable throttle cut ..
A) First I would make sure I have throttle cut set up .
B) Then I would make sure my channels are correctly set up
C) Some channels may need reversing ..
In my Taranis my H36 is set up
AETR
Mar 19, 2019, 09:50 PM
Does the irx4 Plus work with the Nirvana and the mjx bugs 8 Pro?
Mar 19, 2019, 10:07 PM
old4570's Avatar
Mine do not ...
Deviation is ported to MJX Bugs 3 ... I have a MJX Bugs 6 and the protocol allows me to use my Jumper T8SG+
I would check the firmware updates and see if it is on the latest update .. ( IRX4 )
I have not updated my IRX4 ..
Rather I am waiting for a new Module to be released , something more plug and play , or plug in your USB cable and flash ...
Mar 28, 2019, 09:47 PM
britinoz's Avatar
I'm hoping some one will know if this unit will plug into a JR 9x...old school TX
Happy Landings
Chris...
Jul 21, 2019, 02:30 AM
OpenUAS
openuas's Avatar
It will...
Mini-Review iRangeX IRX4 2.4G 4-in-1 Multiprotocol JR-type Module Datos Radios 328 Aug 17, 2019 10:42 AM
New Product iRangeX IRX4 Plus CC2500 NRF24L01 A7105 CYRF6936 Multiprotocol TX Module--FREE TEST BG Tobey Radios 702 Aug 16, 2019 12:01 PM
Mini-HowTo How To Setup - iRangeX IRX4 2.4G 4 IN 1 STM32 Multiprotocol Module Jet_Flyer Radios 328 Aug 11, 2019 01:36 PM
