Nov 10, 2018, 03:09 AM
Droning on.
Yets's Avatar
I bought this one;
https://www.aliexpress.com/item/XH-R...788212208.html
Nov 10, 2018, 08:53 AM
Team WarpSquad
Phoboss's Avatar
I'm using the aliexpress one (12V 48W, from the link posted by Yets), it works great.
It needs 4A PSU, draws slightly more than 3A.
May 19, 2019, 03:29 AM
Kit now available
Hi guys
Thanks to Pavel for all his hard work. I have gone into the trouble to redesigned the board and added a lot of goodies.
Now the new board has :
1 x fan output
1 x Buzzer
1 x port interface in case of using max66750 or max31855 thermocouple sensor
1 x reset switch
1x led heater on
2 x additional sensor ports ntc unpopulated
with the standard basic schematic
1x Rotary encoder
1x oled 0.91" 128x32
1x mosfet driving circuit to heater connector
1x input regulator and diode!
Available as a kit . ready Assembled or bare pcb!
May 20, 2019, 01:32 AM
Hello jasonmrc,
could you tell us where to buy?
What prices?
May 20, 2019, 02:02 AM
Thank you @jasonmrc!
Good job!
BTW: Do you also include to the kit a heating plate? I think this is what most had trouble to find...
Help! how to clean reflow solder paste from needle tip? protocol DIY Electronics 3 Jun 09, 2015 10:46 AM
Discussion Can I silver solder brass to something nickel plated? CyberJay The Builders Workshop 1 Feb 03, 2011 12:18 PM
Mini-HowTo DIY - Diamond plate decking ken_nj Dock Talk 7 Jan 01, 2011 01:26 PM
Help in Soldering Gold Plated Connectors m4tm Power Systems 3 Jan 04, 2004 08:09 PM
