Jan 28, 2018, 02:51 PM
Yes.
It is one of the first reflows.
Reflow soldering on ceramic plate (0 min 30 sec)
One day will make a full fideo...
Jan 29, 2018, 10:32 AM
Updated second post with some photos of final version...
Jan 29, 2018, 11:49 AM
Nice! But I still dont get it, how do you do the reflow on the second side of the PCB? The bottom side gets reflown also...?
Jan 29, 2018, 12:47 PM
It depends...
Sometimes it is easier to do it by solder iron, warming up a PCB a little with this plate.
Solder with solder paste (0 min 38 sec)
If you have small smd components from both sides, then just make another side the same way. But you need to put the PCB on small supports, that components doesn't touch the plate (seems I did not have any photo of that). And then set a bit higher temperature, let's say 20 deg more.
Recently I finished an controller for hot air gun, so, now I can help the process wit air hot too.
It is also possible to reflow bigger boards...
Description:
Jan 29, 2018, 03:21 PM
Team WarpSquad
Phoboss's Avatar
This chip is easy QFN packages with gnd pad underneath are really hard, like qfn32 (i.e. RTC6705)... That's the only thing I struggle to solder reliably :/ Too much solder paste, and blob on the gnd pad causes the whole thing to lift, not enough, and you get shorts as gnd pad pulls too closely to the pcb.
Do you have a method how to solder these packages at home? Usually I have to redo the process 2-3 times until it's right. Hot air helps a lot
Jan 30, 2018, 01:56 AM
Yes, these packages is not easy to solder.
What I found is helpful: while pcb design, Im trying to put couple of vias from this gnd pad to other side of pcb if possible.
I know, this is not recommended for mass production, but for me it works.
Also, while applying solder paste, I'm starting from these big pads and trying to use paste as less as possible. If it is too much, then I'm wiping everything and starting again.
EDIT: Ah yes, and often, while reflow stage, i'm touching questionable components with toothstick to see, are they seat good? They should move like on a drop of water. Also try to push a bit these components. Excess solder will go away through via holes.
Mar 25, 2018, 06:19 PM
Nobert's Avatar
What is the status of project?
Neal
Mar 26, 2018, 03:47 AM
Project is finished. And I'm very happy with the results.
Or is there any information is missing?
Mar 26, 2018, 04:26 PM
Nobert's Avatar
Thanks for reply. I'd like to build one. Where is all the info, ie:schematic, code, controller etc.? Are you offering a kit of parts?
Neal
Mar 26, 2018, 04:33 PM
Droning on.
Yets's Avatar
Same here, I'd like to build one also but the github doesn't have any information regarding "other smd components", I guess resistors and caps. Is there a BOM?
@Nobert: Code and parts are in he github link, it's just missing the smd parts
Mar 27, 2018, 03:23 AM
Ah, sorry. Here it is: https://github.com/nppc/Heater12VCon.../master/BOM.md
Mar 27, 2018, 06:54 AM
Droning on.
Yets's Avatar
Originally Posted by nppc
Great! Thanks, I have nine FC boards to make!
Mar 27, 2018, 08:31 AM
Nobert's Avatar
nppc
How about the schematic?
Thanks. Parts are on order.
Neal
PS: Here's a Mosfet that's easier to source for a 12 volt system: 757-TPH1R712MDL1Q
Mar 28, 2018, 01:31 AM
Droning on.
Yets's Avatar
Any recommendations for an alternative heating plate?
Mar 28, 2018, 01:40 AM
Team WarpSquad
Phoboss's Avatar
I'd also like to know that, it is out of stock on banggood since the beginning of this project..
Help! how to clean reflow solder paste from needle tip? protocol DIY Electronics 3 Jun 09, 2015 10:46 AM
Discussion Can I silver solder brass to something nickel plated? CyberJay The Builders Workshop 1 Feb 03, 2011 12:18 PM
Mini-HowTo DIY - Diamond plate decking ken_nj Dock Talk 7 Jan 01, 2011 01:26 PM
Help in Soldering Gold Plated Connectors m4tm Power Systems 3 Jan 04, 2004 08:09 PM
