PWM Meter - Servo City
Here is another handy unit from Servo City...
PWM
Need to know what PWM signal your receiver, robot or servo controller is sending? Simply plug in our PWM Meter to see a readout of the PWM signal in microseconds (Ásec). If you wish to pass that signal on to your servo or device, just plug into the other set of header row pins.
Specs
  • Product Weight - 0.20 oz
  • Input Supply Voltage Range - 4V - 15V
  • Current Drain - 55mA @6V
  • PWM Signal Range - 0 - 9999 Ásec
  • PWM Signal Resolution - 1 Ásec
Images
Learn More
Head over to Servo City to learn more about this handy unit.
New Product New PWM Meter & Low Voltage Cutoff Switch ServoCity Product Announcements 0 Nov 30, 2017 02:56 PM
Question FRSKY SBUS CPPM PWM Servos flyingdreamz Radios 0 Apr 08, 2016 12:04 AM
Discussion X4R, SBUS to PWM converter, frame rate and analogue servos sabre2 Radios 6 Sep 25, 2015 07:54 AM
Help! Walkera Q pwm > ppm & Q pwm>B pwm (broke) SadSack DIY Electronics 7 Mar 20, 2010 07:18 AM
