ISDT BattGo BG-8S Smart Battery Checker
Keep your batteries in the best shape possible with this multi-function cell checker and balancer from ISDT.
Test Batteries, Balance Cells, and Analyze PWM, PPM, and S.BUS Signals
The ISDT BattGo BG-8S is a multi-function battery tester that provides a number of innovative options for under $30. Not only does it display vital cell info on its 2.4” 320x240 display, but it also balances cells and tests receiver signals from PWM, PPM and S.Bus sources. Additionally, the BG-8S has USB outputs at 5v to charge a cellphone, tablet, or other USB chargeable electronics. Here's what Hobbyking says about the new ISDT BattGo BG-8S Smart Battery Checker:
From the Hobbyking Website:
The ISDT BG-8S Smart Battery Checker is a new style of multipurpose battery checker. It is specifically designed for hobbyists of Remote Control products. It comes lots of great features to help check your batteries, receiver signals and even has a USB output that allows you to charge your phone or other devices. The Battery Checker has a 2.4” 320x240 display that can easily be seen in sunlight and has an easy to use menu system to show all functions and data.
There is an advanced balancing algorithm to ensure every cell is well balanced. Most batteries types are supported such as LiHv, LiPo, Lilon, LiFe, NiMh/Cd as well as checking your BEC output. If you want to charge up your USB devices (phones, tablets, etc) you only have to connect up a battery to the XT-60 and the BG-8S can become your power bank for mobile devices. The BG-8S also tests receiver signals and currently supports multiple protocol analysis including PWM, PPM&S.BUS with more to come.
CLICK HERE for more information on the ISDT BattGo BG-8S Smart Battery Checker
Features and Specs:
  • Battery voltage check
  • Battery balancing
  • Power bank for mobile devices
  • Receiver signal test and protocol analysis
  • Upgrade via USB port
  • Multi language support
  • Working voltage: 5.0V - 36V
  • Input voltage 1s: 0.8V - 15V
  • Input voltage 2-8S: 0.8V - 4.8V
  • Battery cells: 1-8S
  • Voltage measurement accuracy: ±0.005V @ 4.2V
  • Balancing cells accuracy: <0.005V
  • Support USB charging: Q2.0/C3.0, BC1.2, Maximum output 12V/2A
  • Support smart battery: Charging and discharging setting, read battery info and usage history
  • Supported Batt. Type: LiHv (1-8S) / LiPo (1-8S) / LiFe(1-8S) / Lilon (1-8S) / NiMH/Cd(1-10S)
  • Display: 2.4” 320×240 260,000 color IPS LCD
  • Dimension: 80x55x19mm
  • Weight: 59g
  • Operating Temperature: 0-40℃
  • Working Humidity: 10%-90%RH (noncondensing)
  • Storage Temperature: -20-60℃
  • Storage Humidity: 5%-90%RH (noncondensing)
Dec 01, 2017, 09:12 AM
parajared's Avatar
One of these is the solution to solar charging lipo batteries. When you flow energy into your lipos directly off a solar panel they get out of balance after a while and something like this can square that away for you.
Dec 01, 2017, 09:31 AM
Matt Gunn's Avatar
Excellent use of that balancer!
Dec 01, 2017, 07:49 PM
Got one of these on Banggood snap sale. Excellent device for the money!
Mini-Review ISDT BG-8S Smart Battery Checker with BattGO Technology czajunia Batteries and Chargers 46 Jan 31, 2019 10:09 AM
New Product ISDT BG-8S Smart Battery Checker/Balancer/Rx Signal Tester/Power Bank D Gains Batteries and Chargers 1 Jun 23, 2018 10:20 AM
New Product ISDT T8 BattGo 1000W 30A Smart Battery Balance Charger For 1-8S Lipo Battery Livershifter Banggood.com 10 Nov 29, 2017 12:38 PM
New Product Battgo&ISDT smart battery checker-BG8S ISDT Batteries and Chargers 28 Oct 05, 2017 01:55 PM
New Product ISDT BG-8S Smart Battery Checker Balancer Receiver Signal Tester Quick Charge Functio smg24 Banggood.com 0 Jul 26, 2017 07:07 AM
