Nov 29, 2017, 11:51 AM
jhaywood's Avatar
Very Best Micro Servo
What is the best micro servo available? Cost is not an issue.
I need the most precise, fastest, and slop free servo available.
It cannot be a heli tail servo designed to work only with gyros. The have different pulse width.
Nov 29, 2017, 11:57 AM
Sagitta Fanboy
How small do you want to go. For reference, check out what the F3J and F3B community is using, which means mostly MKS 6xx0HV series or Futaba SBus2 servos (with some still using JR stuff if they can find it). The competitive glider community relies on small, strong and fast servos which must have very precise/slop free centering.
Futaba offers a good selection in its Sbus2 line (these will also work on PWM inputs)
S3270SVi HV S.Bus2 Programmable Micro
S3777SV S.Bus2 HV Programmable Micro (10g servo)
With MKS, the 6100HV is the default.
Note that external bearing servo frames are available for these servos, to be combined with LDS kits for the most precise control surface actuation possible.
Nov 29, 2017, 12:54 PM
jhaywood's Avatar
I was looking at the MKS line.
A size reference would be anything between a Hitec hs65 and hs81 size.
Precision is of the utmost importance. Speed should be ok as long as it is .10 sec or faster.
Nov 29, 2017, 02:34 PM
Sagitta Fanboy
.10 second is extremely fast for anything other than a heli tail servo. You can get that performance from some aileron servos for sailplanes, but you'll typically be looking at HS85 size.
The BLS173SV HV S.Bus2 Programmable Mini Air from Futaba is .10sec on 2s and just slightly larger in size (3mm larger in 2 dimensions, 3mm smaller in the third)
The HV6100 is even smaller, with similar performance aside from strength.
Nov 29, 2017, 02:59 PM
RC Guru
Xpress..'s Avatar
Nevermind..
Nov 29, 2017, 04:30 PM
jhaywood's Avatar
The MKS look pretty good. Wish I had real world centering data.
LDS will not work on this project. The control surface will be super small OR I am going to make each wing panel move....think very small. 6x4" or so
Nov 29, 2017, 05:39 PM
Sagitta Fanboy
I'm sure somebody over in the F3X forum under Sailpanes has centering test data, competition molded sailplanes are extremely sensitive to centering, especially on ailerons and elevators. That's largely why there's a relative handful of servos used widely across the community. Pretty much everybody uses 3-4 servos out of the same list of 10-15 MKS, JR or Futaba units.
May 15, 2020, 07:06 PM
The best servos, specs & price point
https://www.promodeler.com/servos
Made in the USA.
May 16, 2021, 02:07 PM
Originally Posted by Wild Doogie
Whow they look to be the bees knees.
May 31, 2021, 04:32 AM
mlachow's Avatar
https://www.deeforce.net/product-pag...tal-wing-servo
The ds118 are nice but only wing mount.
Latest blog entry: Minimoa Restoration
Question Very best micro servo? birdlives1955 Radios 23 Sep 05, 2011 06:50 AM
Best make of micro and sub-micro servos? Prawnik 1/2A Planes 24 Dec 14, 2004 04:32 PM
Best make of micro and sub micro servos? Prawnik Radios 0 Dec 07, 2004 02:43 PM
Question Very efficient sub-micro servos? Steve McBride Radios 3 Aug 07, 2003 02:12 PM
best way into a very micro flier tobi-wan-kenobi Scratchbuilt Indoor and Micro Models 1 Oct 26, 2002 12:00 PM
