Nov 26, 2017, 01:55 AM
Dennis 9412's Avatar
4 port MPA adapter
I recently purchased one of your new 4 port MPA adapters with the XT60 connectors and was not able to hook it up to my Cellpro 10XP charger, which is also new.
It came with the adapter to hook up the batteries to the charger, but there is no way to plug the adapter itself into the charger. The piggyback power connectors are too big to plug into the charger.
Is there an adapter to enable this to happen? According to your website, it says it comes with the necessary cables to hook it to a Cellpro 10XP charger, but I'll be damned if I can see how to do it with the cables that came with it.
If there is an adapter available, why was it not sent with it?
Can you please assist?
Regards,
Dennis
Nov 26, 2017, 03:47 PM
Regards,
Dennis
Just use a knife or pair of scissors to circle around the plastic sheath to cut through and remove it. The covers provide extra protection when used with the Powerlab or GT chargers, but wont work for all models.
Nov 28, 2017, 12:09 AM
Thank You Revokelly,
That worked like a charm!!
Everything is hunky-dory now.
Regards,
Dennis
May 08, 2018, 05:07 PM
4p mpa
Hi there,
I am having some trouble understanding how my 4P MPA ( XT 60 Power Connector) plugs into my Cellpro 10XP charger.
I am trying to parallel charge 3- A123 batteries and can't make it work for me.
I have changed the default wiring mode to XH wiring in the programming mode.
How am I supposed to have the MPA wired to the charger?
I am hooking the main pack leads of the MPA to the outer poles of the charger, and the balance charging leads from the MPA into both channel 1 and 2 of the charger. When I push the start button the charger says that channel 1 has no pack. What am I doing wrong?
Can someone post a photo of how it should be hooked up? This is not a very user friendly charger, or maybe I'm an idiot?
Can someone please help me?
Regards,
Dennis
May 10, 2018, 04:07 PM
Anybody??
May 11, 2018, 10:40 AM
Hi Dennis,
Please send me an e-mail and I will assist you, jamie@revolectrix.com.
Question Explain the Benefits of the Multi-Port Safe Parallel Adapter (MPA) torquenut Revolectrix 4 Nov 25, 2012 09:06 PM
Discussion 2 CP8S-TP/PQ6S-PAR Safe Parallel Adapters or MPA board traxx de maxx Revolectrix 2 Sep 04, 2012 03:42 PM
Question thunderpower 4 port 1 cell charger with my e-flite 1.5amp adapter 18t Batteries and Chargers 3 Apr 04, 2011 10:06 AM
Discussion TME 4 port adapter for 1s 3.7 batts Tubeheadz Batteries and Chargers 3 Dec 22, 2009 01:39 PM
Discussion Charging a Thunder Power 2cell lipo with a Venom 3cell charge port and 4 wire adapter modfly Batteries and Chargers 0 Jun 22, 2008 11:49 AM
