Nov 24, 2017, 02:01 PM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
F2 Mito210 210mm FPV Racing Quad Freestyle True X Frame
https://www.banggood.com/F2-Mito210-210mm-FPV-Racing-Drone-Freestyle-True-X-Frame-Kit-Carbon-Fiber-4mm-Arm-p-1231144.html
Description:
Item name: F2 Mito210 frame kit
Wheelbase: 210mm(5 inch)
Arm thickness: 4mm
Bottom plate thickness: 2mm
Upper plate thickness: 2mm
Side plate thickness: 1.5mm
Height of aluminum column: 30mm
Camera angle range: 0-60
Weight: 82g
Material: 3K carbon fiber
Color: red/black (optional)
Features:
Quick disassembly design.
4mm independent arm, fast demolition, unique design virtual bit less.
We also designed a fixed four arm of the aluminum alloy, so that the arm is not easy to shift.
True X structure, suitable for racing with Freestyle fancy flight.
The position of the motor compartment is widened and the collision is not easy to hit the motor.
Machine all use 12.9 strength YFS screws.
According to individual needs, can choose the frame assembly of battery on or under.
support HS1170, Swift, RunCam Eagle 2, Foxeer Arrow V3 HS1195, RunCam Sparrow, Swift 2 MINI, OVL and other lenses.
Recommend parts:
Flight controller: F4/F3/Naze32/CC3D
Motor: 2204/2205/2206/2305/2306/2405...brushless motor
ESC: 20-30A brushless ESC
Propeller: 4-5 inch (4XXX/50XX)
Battery: 3/4S 1300-1800mAh lipo battery
This product is an empty machine version, without any electronic equipment.
Package included:
1 x F2 Mito210 frame kit
KIT ONLY !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
New Product Realacc Blackbird 205 210mm 4mm Arm Thickness Carbon Fiber FPV Racing Frame 90g smg24 Mini Multirotor Drones 0 May 16, 2017 10:06 AM
Discussion Razorquads X5 racing frame - 185mm true X 5 inch props kevintmckay Mini Multirotor Drones 81 Nov 01, 2016 08:08 AM
New Product FPV Race Quad Sets GB210, GB190 X-Frame snappyhh Mini Multirotor Drones 3 Oct 23, 2016 09:51 PM
Discussion If you had to build another 210mm race quad, what frame would you buy? spllouder FPV Racing 45 Oct 13, 2016 06:27 AM
