This thread is privately moderated by WRXronald, who may elect to delete unwanted replies.
Nov 22, 2017, 10:37 PM
Trader Rating: 6
$99.00 USD
Buyer pays shipping
Sold
NOVAK SuperDuty XR -- Dual Motor ESC -- Tamiya ClodBuster
I guess this fits Trucks & Parts --- more like electronics, but for your truck!
Old & Rare & Hard to find for sure!! You'll pay no less than $139 on Ebay if you're looking for one today.
NOVAK SuperDuty XR ----
twin 540 brushed motor -- very versatile!
Perfect for Tamiya ClodBuster Axles running dual motor-over-axle setups in Rock Crawlers, etc.
Currently wired to a large powerful single 540 motor with integrated cooling fan! approx. 25T!
On the bay too for a 3 day auction!!!
https://www.ebay.com/itm/32289902571...84.m1555.l2649
Item Description
This is a Novak XR Super Duty Reversible ESC for brushed motors, part number NOV1865. This high powered ESC can be used for a variety of 1/10 scale rock crawlers and 1/8 scale super class rock crawlers, such as the Tamiya Super Clod Buster, TXT and Traxxas E-Maxx.
Features Novak glitch buster, dual Tamiya battery connectors and needs to be soldered direct to your motors (which are run in parallel).
This ESC has been discontinued and is no longer produced by Novak Racing.
This is lightly used and in very good condition with minor surface wear from normal use. This has been tested and functions perfectly.
Manufacturer's Description:
Super Duty XR: Beefy, Rugged, Powerful & Tough!
Forget small and lightweight. Novak's Super Duty XR High-Voltage Reversible ESC is exactly what every monster truck and large-scale vehicle driver is looking for: a heavy-duty, high-voltage reversible ESC that delivers high performance and is built to last. This powerful, 100% digital microprocessor-controlled ESC easily handles 6-14 cells, which means dual 6 or 7-cell packs are easily accommodated. With a super-low On-Resistance of 0.0011ohms, a Rated Current of 400 amps, and a Braking Current of 180 amps, the Super Duty XR provides impressive performance and power.
Three throttle programs give drivers additional flexibility.
Program #1 is the default setting that allows forward, brake, and reverse functions.
Program #2 contains the Reverse Disable feature that allows drivers to turn the Super Duty XR into a forward-only ESC, a must for racing.
Program #3 is for marine use*. This mode allows forward, as well as 25% reverse and brakes.
The Super Duty XR is one of the most durable and highest performance ESCs available. With its much higher current-handling capability, heavy-duty 6 volt/3 amp BEC, and lower motor limit, the Super Duty XR is the perfect upgrade for the Traxxas E-Maxx’s EVX. With the same footprint and screw pattern as the EVX, the Super Duty XR easily bolts right into the Traxxas E-Maxx. Because the Super Duty XR is designed for large-scale vehicles, it is the ideal ESC to install in Kyosho’s Twin Force, Tamiya’s TXT-1 and Clodbuster, as well as any other 6-14 cell applications.
Built-in Thermal Overload Protection and strategically placed gaskets throughout the ESC make the Super Duty XR extremely dependable. While Thermal Overload Protection provides extra safety and protection against thermal overloads, gaskets around all the MOSFET openings, One-Touch Set-Up Button opening, and wire openings help provide added protection against dirt and water.
The Super Duty XR also comes equipped with Novak’s new Smart Braking II feature, which provides full braking power. Smart Braking II allows more controlled braking, which gives R/C drivers a full range of braking without worrying about accidentally sending the vehicle into reverse. To engage reverse, the driver must return the throttle to the neutral position, then “shift” into reverse by returning the throttle toward the reverse/braking direction. This feature gives the driver more controlled take-offs in reverse, while being easier on the car’s drive train. When expertly maneuvering a vehicle down a challenging embankment, Smart Braking II is one of those great subtle features that users won’t even be aware that they’re using, but wouldn’t want to be without!
Like the newly released GTX ESC, the Super Duty XR is built with six layers of gold-plated powerboards, which help increase its power-handling capabilities. Likewise, the low-resistance Direct Solder Wire Tabs are also gold-plated. When used with the included Novak Super-Flex silicone wire, not only are users assured of the lowest possible voltage drop, but also changing power wires, the switch harness, and the power capacitor is extremely easy. For added convenience, the Super Duty XR comes with a user-replaceable input harness. Another amenity is a 2-Pin Connector Slot for an optional 5-volt accessory fan (#5646 Power Boost ESC Fan Kit).
The Super Duty XR High-Voltage Reversible ESC is a heavy-duty, high-voltage reversible ESC that is designed for large-scale vehicles. It may be big and beefy, but the Super Duty XR ESC delivers high performance and is built to last!
*The Super Duty XR is not waterproof. Users must take steps to prevent water damage to the ESC.
SUPER DUTY XR SPECIFICATIONS
Input Voltage: 6-14 cells (1.2 VDC/cell) [Forward/Braking/Reverse] or 2-4S Li-Po when used with Novak Smart-Stop Li-Po Module (#5470, #5471 or #5472)
Footprint: 1.75” x 2.17” (44.5 x 55.1mm)
Motor Limit
# Cells Single Motor Dual Motors in Parallel
6 cells (7.2 volts) None 10 Turn
10 cells (12 volts) None (550 Size Only) None (550 Size Only)
12 cells (14.4 volts) None (550 Size Only) 12 Turn (550 Size Only)
14 cells (16.8 volts) None (550 Size Only) 12 Turn (550 Size Only)
On-Resistance: 0.0011 ohms (Forward)
Rated Current: 400 Amps (Forward) @ 25°C MOSFET Temp.
Braking/Reverse Current: 180 Amps @ 25°C MOSFET Temp.
BEC: 6 Volts/ 3 Amps
Maximum Discrete Steps: 512 (256/Forward, 256/Reverse)
Motor/Battery Wire: 14 Gauge
SUPER DUTY XR FEATURES
100% Digital Microprocessor-controlled
3 Throttle Programs
Ideal for Dual Battery Packs
Gold-Plated PCB Direct-Solder Wire Tabs
Smart Braking II
Gasket Protection
Power Output for 5-Volt Accessory Fan (#5646)
Reverse Disable (Program #2)
25% Reverse & Brakes (Program #3)
User-replaceable Input Harness
One-Touch Set-Up
Radio-Priority Circuitry
Polar-Drive Circuitry
Digital Anti-Glitch Circuitry
Sold RC4ZE0008 RC4WD Outcry Dual Motor Crawler ESC w/Fan & Turbo BEC clodbuster etc. northerngames Cars - Trucks and Parts (FS/W) 0 Feb 12, 2017 10:35 PM
For Sale RC4ZE0008 RC4WD Outcry Dual Motor Crawler ESC w/Fan & Turbo BEC clodbuster etc. northerngames Cars - Accessories (FS/W) 0 Jan 30, 2017 06:36 PM
For Sale RC4ZE0008 RC4WD Outcry Dual Motor Crawler ESC w/Fan & Turbo BEC clodbuster etc. northerngames Cars - Trucks and Parts (FS/W) 0 Jan 30, 2017 06:29 PM
Question ESC Tamiya TBLE-02S is work/compatible with motor novak? galaxy1 Electric Power Cars 9 Jan 30, 2017 06:09 PM
For Sale Novak SuperDuty XR WRXronald Cars - Cars and Parts (FS/W) 0 May 07, 2011 09:31 PM
