This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Nov 22, 2017, 06:32 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
New Product
New DJI Goggles Race Edition with Analog FPV and Ocusync Camera
DJI have release a new updated version of the Goggles called the Racing Edition
My DJI Goggles Update and Info Blog is located here if you would like more info
https://www.rcgroups.com/forums/show...nofficial-Blog
This new version of the goggles carries quite a large number of upgrades over the standard model, along side the Ocusync receiver and HDMI or USB input DJI have added a 12 channel analog receiver with DVR to support FPV analog transmitters, the goggles have an improved redesigned visor and headband with new red leather covering over the foam, along side these updates DJI have also expanded the goggles playback support to include MP4, MOV, MKV.
DJI Camera Module & Ocusync Air Unit
Along side the updates goggles DJI have release an optional brand new 1.2MP Digital FPV Camera with global shutter and 148 degree FOV, this connects to a all new standalone Ocusync air unit to allow users to add DJIs digital Ocusync system to stream HD low latency video up to 7km in range on any craft.
This digital standalone Ocusync air unit is also fitted with its own DVR for recording the digital FPV feed, when using this system you can also connect your RC directly to the goggles and control you flight controller via SBUS or PPM via the air units outputs.
Overall this is a massive upgrade to the DJI Goggles making them compatible with existing FPV systems as well as for the first time bringing Ocusync digital low latency FPV feed to any system you want with the camera and transmitter.
Main Differences between the 2 models.
In addition to the 2.4GHz digital transmission band, the new DJI Goggles RE also supports the 5.8GHz band, which can avoid the usual interference on the more crowded 2.4GHz.
DJI Goggles RE has redesigned the internal linear polarized omnidirectional antennas and added new external Pagoda antenna, a 5.8GHz single-frequency omnidirectional left hand circularly polarized (LHCP) antenna.
DJI Goggles RE has restructured the radio communication strategy and video decoding algorithm to lower transmission latency to 50 ms* (with wireless transmission latency of less than 10 ms), ensuring smooth and reliable video transmission and avoiding video lag and disconnection from the digital video transmission system when operating in a normal environment.
DJI Goggles RE supports analog transmission at any integer frequency between 5.650~5.925 GHz and analog video storage on a Micro SD card.
DJI Goggles RE can store digital video on a Micro SD card.
DJI Goggles RE supports local video playback and Sphere pano viewing, allowing users to turn their head to get a 360 view of the Sphere pano.
The facial pad has been redesigned and the headband has used new replaceable leather materials to make it even more comfortable to wear.
DJI have priced the new Goggles Racing Edition at $549
They also offer a DJI Goggles Racing Combo deal that includes all the extra antennas, Camres and Air unit for $859
For more info on the DJI Goggles RE or to order from DJI see below
http://click.dji.com/AMjx08RDK2VQyo0...m=link&as=0020
More Info
OcuSync Video Transmission Module
DJI Goggles deliver FPV video with ultimate speed, stability, and clarity. The OcuSync Video Transmission Module offers 2.4 and 5.8 GHz dual-band digital video transmission with latency as low as 50 ms and a maximum control range of up to 7 km.1 Equipped with an array of powerful features, such as 1280960 HD transmission,3 and automatic Frequency-Hopping Spread Spectrum (FHSS) transmission, this module is compatible with a variety of multi-rotor and fixed-wing aircraft. Packed with advanced tech and features, as well as external modules to suit a variety of setups, DJI Goggles RE achieve immersive drone racing that is unparalleled.
12 Selectable Digital Video Channels
Access to low-interference transmission channels is the key to success for competitive FPV racing, especially when multiple drones are flying simultaneously. Manually choose from up to 12 transmission channels to effectively avoid interference. 4
Camera Module
The DJI OcuSync Camera compatible with DJI Goggles RE uses a 1/3 image sensor, providing much higher-resolution
video transmission than most analog FPV goggles on the market. It also uses a global shutter, significantly reducing rolling shutter effect caused by high-frequency vibration. Also, its 148 FOV with a low-distortion lens delivers a wide, yet natural-looking camera view. With such an advanced camera, users can control flight accurately and even record a whole flight for analysis or sharing.
Compatibility
Fully compatible with the usual 5.8GHz FPV Bands ( A/B/E/F/C &Raceband) , up to 40 channels in total. It also receives up to of 275 integer frequencies between 5650~5925 MHz, in which Band C (Raceband) includes 8 channels and the channel interval is 27 MHz.
As well as this is still supports all the latest DJI Models such as the DJI Spark, Mavic Series, Inspire 2 and Phantom 4 or any HDMI device.
New 5Ghz Ocusync Support
FAQ
The original DJI Goggles will bind with the new Ocusync received but you would have live feed only, there is no way to connect a controller into the goggles for control with the standard ones.
The Ocusync air end supports the Multiwii protocol for telemetry so it will give some limited OSD when connected to a compatible Flight Controller , it will show battery voltage, wireless signal and altitude.
The Mavic RC will bind to the air end Ocusync but as of now you can not use it as a controller,
DJI Support Video on Linking to 3rd Party RC
DJI Goggles RE | Connecting a Third party Remote Controller and Flight Controller (1 min 52 sec)
Please note all links may be affiliate links.
Nov 25, 2017, 10:33 PM
Will the DJI Camera Module & Ocusync Air Unit connect with the old DJI goggles? Or does it only work with Race Edition?
Dec 02, 2017, 08:28 AM
Ok some updates
  • The Standard Goggles will bind with the new Ocusync received but you would have live feed only, there is no way to connect a controller into the goggles for control with the standard ones.
  • The Ocusync air end supports the Multiwii protocol so it will give some limited OSD when connected to a compatible Flight Controller , it will show battery voltage, wireless signal and altitude.
  • The Mavic RC will bind to the air end Ocusync but as of now you can not use it as a controller
DJI Have release an video demonstrating RC Control
Dec 04, 2017, 07:58 AM
no it work with old goggle white they is a video on youtube
News DJI Goggles Racing Edition Jason Cole FPV Equipment 1254 Jan 18, 2020 06:00 AM
Mini-Review First FPV quad. RS-220 Racing Quad with Furibee VR01 Goggles. I'm new to FPV. hifinsword FPV Aircraft 16 Sep 04, 2017 05:59 AM
Discussion editing of a analog fpv video? look001 FPV Talk 2 Apr 01, 2016 04:15 AM
