Nov 22, 2017, 08:13 AM
lipo disposal setting
is there a setting on the PL6 i can use to completely discharge a lipo prior to disposal?
Nov 30, 2017, 06:34 PM
anyone?
Dec 01, 2017, 08:36 AM
JMynes's Avatar
I use automotive light bulbs to discharge for disposal. Why use an expensive charger to drain a piece of trash?
I built a bank of 10 bulbs, two sets of 5, and monitor pack temperature by feel. When it gets hot I give it a break, and unplug a few bulbs before discharging some more.
Once the bulbs won’t glow I check with a clamp on ammeter, and if the current is minimal I clip the leads, strip them back, and wire nut them together. I place the battery on a fireproof surface and let it sit for a few hours, usually overnight, before disposing of it in the local battery recycling bin.
Dec 01, 2017, 09:22 AM
We follow the same procedure that JMynes follows. To answer your initial question, the charger will not discharge completely.
REVO USA
Dec 02, 2017, 08:25 AM
Michael
I built a similar setup, but as I use 2S to 6S LiPos, I used automotible taillight bulbs setup with Andersen Power Poles (AKA Sermos) so that I can choose serial or parallel, or both. The taillight bulbs have a low and a high resistance drawing about 2 amps or 0.5 amp. I use the 0.5 amp side for the smaller capacity LiPos...
One other club member built a copy of my unit, but everyone else simply asks me to dispose of their LiPos. It works great and I agree that I would not want to expose my expensive charger to a piece of trash...
I originally thought I could simply insert / remove bulb(s) to handle the voltage and desired load, but the automobile bulbs are push/twist and I did not want to do multiple insertions/removals. Screwin would be better, but I used what was available.
Michael
Feb 11, 2018, 04:00 PM
HaDi-RC.de's Avatar
It would be good enough to allow dsc-mode to discharge in cc-cv mode incl. balancing, so all cells would be discharged to 3.0 V idle voltage, batt. can be disposed w/o danger. Even on short circuit, energy wouldnt be enough just to heat up single cells. And if used accidently, battery doesnt run immediate risk of damage if charged up immediately.
Discussion FrSky Mini Lipo Voltage Sensor set my plane on fire-- ok to keep using? aeronaut999 Radios 10 Jun 08, 2018 06:41 PM
Discussion Lipo charge settings? chlorine Batteries and Chargers 2 Aug 15, 2016 01:15 AM
Discussion Novak Velocity GTB 4.5r Brushless Set Max Lipo Value kifidis Car Talk 1 Apr 20, 2016 07:25 PM
Question How to set up this ESC for lipo? LifeofBrian Power Systems 6 Sep 29, 2015 08:26 AM
Discussion LIPO Trick 2: Setting Up a LIPO VOLTAGE CLAMP hall woo Batteries and Chargers 0 Oct 13, 2006 09:59 AM
