HOBBY EAGLE New A3Super3 known as A3S3 questions and answers
I am starting a new thread for the New HOBBY EAGLE A3super3 known as the A3S3 Gyro. The gyro does so much more than the A3Super or the A3Super II it started getting too much confusion what gyro people were asking questions about.
New thread on the A3SUPER4 https://www.rcgroups.com/forums/show...per-4-Mini-etc The thread I started back in Oct 2013 are for the older a3Super and SuperII https://www.rcgroups.com/forums/show...rs-gyro-system User manual for the A3S3 http://www.hobbyeagle.com/manuals/A3...al_v1.0_en.pdf You will find that the black program box is different for the A3S3 plus now they include a remote data controller that the program box plugs into. |
Sold on banggood:https://www.banggood.com/HobbyEagle-A3-Super-3-A3S3-6-Axis-Airplane-Gyro-Flight-Controller-Stabilizer-p-1228811.html
Overview: A3 Super 3 (hereinafter referred to as A3S3) is a high-performance and functional 6-axis gyro and stabilizer designed for RC airplanes. This gyro can be used with nearly any size and type of R/C airplanes and it will make the flying even easier and comfortable. Specification: Brand Name: HobbyEagle Item Name: A3 Super 3 Version(optional): Standard Version, Full Set Version (with program card) Main Controller: 32-bit MCU Sensors: High-precision 3-axis gyroscope and 3-axis accelerometer Gyroscope Scale Range: ±2000dps Accelerometer Scale Range: ±4g PWM: 920uS ~ 2120uS with 1520uS center length / 50~333Hz Input Voltage: 4.8V - 8.4V Operating Temperature: -10℃ - 50℃ Size: 43×27×14mm Weight: 10g (excluding wires) Features: 32-bit MCU, high-precision 6-axis MEMS sensor, improved hardware platform and new firmware solution provide more reliable performance. Supports 6 flight modes, including Gyro-Off mode, Normal mode, Trainer mode, Atti-Lock mode, Auto-Level mode and Auto-Hover mode. Supports 6-position flight mode switching. Supports 7 wing types, dual aileron, dual elevator, delta-wing and v-tail supported. External LED module, integrated with data interface, flat or upright various mounting orientations supported. Compatible with most standard receivers, standard PPM single-line receivers and Futaba’s S.Bus and S.Bus 2 receivers. Sub trim and travel limit settings for servos, separate stick Rate and EXP settings for each mode. Pass-through function for [A2] and [E2] channels. Customizable hardware and software low pass filters for gyroscope and accelerometer, enable you to optimize the performance of the gyro as you wish. Quick setup supported by using the programming card while flying outside. Note: The Standard Version does not include the program card. Please select the version you need. Setup Software V1.0, http://www.hobbyeagle.com/download/A...ility_v1.0.msi USB Driver, http://www.hobbyeagle.com/download/C...K3_Vista_7.exe Online Firmware Upgrade Tool V1.0, http://www.hobbyeagle.com/download/F...te_Utility.msi English Manual, Click Here |
In that case I will close the existing thread:_
https://www.rcgroups.com/forums/show...ght-Controller One of my pet-hates when several threads run at the same time. Odd because you even posted on that one but your call. Paul |
Latest blog entry: Just To Say Hello.......
FWIW you have to buy at least one complete version with a program card due to your old program cards will not work with the new A3S3 gyro. |
HobbyEagle A3 Super 3
Banggood $29.99 for Standard version without programming card $47.99 for Full Set version with programming card AliExpress $31.04 for Standard version without programming card $67.35 for Full Set version with programming card RC-Castle $34.98 for Standard version without programming card + $6.90 shp = $41.88 (to Virginia) $54.99 for Full Set version with programming card + $6.90 shp = $61.89 (to Virginia) Amazon (15% off Standard version and 10% off Full Set version if more than 1 purchased, restrictions apply) $34.91 for Standard version without programming card $53.86 for Full Set version with programming card I will add other retailers reported on this post. Don |
What extra features does it have over the A3S2?
(I only ever use "Normal" mode anyway, so having 3 additional switchable modes doesn't do much for me). |
Latest blog entry: Do-it-Yourself EDF Afterburner and other...
[QUOTE=Go4it;38677479]
I'd like to know specifically what this does that the SuperII can't. So far, I've only seen a couple things such as an additional flight mode or 2 and some passthrough thing. |
Programming Examples for 6-position Switch Mixing
One of the most interesting changes made to the Hobby Eagle A3 Super3 is the 6 position MODE switching for 6 different position outputs.
http://www.hobbyeagle.com/gyros/6pos_mixing.php?lang=en |
Thread Tools | |
Similar Threads | |||||
Discussion | HOBBY EAGLE A3 super A3 SUPERII New GYRO A3S3 questions and answers gyro system | Go4it | Electric Plane Talk | 5717 | Mar 11, 2024 06:57 AM |
Discussion | Rally in Charlottesville - New questions to be answered. | BrassNuggets | Life, The Universe, and Politics | 28 | Aug 21, 2017 11:19 PM |
United hobbies is sending out packs known to be defective as replacments | Nethole | Batteries and Chargers | 0 | Sep 21, 2007 08:32 AM |
