Aug 04, 2019, 10:31 AM
SilbernerSurfer's Avatar
Thanks for the hint about the diff. I was able to find a pair for $9 shipped. The original ones on the VRX page are around $17 for one!
Yes, the spokes are slim, but for my purpose they will work, I guess.
There are around 4 or 5 different rims available with these tires. For example:
https://de.aliexpress.com/item/32828...chweb201603_52
Aug 16, 2019, 04:44 PM
Is the stock ESC the one which can handle 3s too? In the manual are 3 different types of ESC's listed. H0050C can handle 3s too!
Aug 17, 2019, 07:36 AM
Car Bashing
Jym73's Avatar
That's what i say at the end of my unboxing video about the esc. We don't know which ESC we have. On the ESC's PCB there is : DAX-H0050-P
Aug 17, 2019, 10:46 AM
In the manual are drawings of each of the ESC's. You can see which one it is by the look!
Aug 18, 2019, 03:27 PM
May someone post a pic of the ESC from above, please? Possibly I will be able to name the ESC then.
Aug 19, 2019, 01:29 AM
Car Bashing
Jym73's Avatar
I have the A ESC.
Aug 19, 2019, 06:33 AM
Thanks, Jym!
Aug 23, 2019, 04:41 AM
How can I extend the steering link ?? I got a xtraspeed titanium link and the threads are cut into the material...so no swap of the set(grub)screw... What can I do ...its missing almost 1 cm each side ??
Aug 23, 2019, 05:43 AM
Which thread size? M3, M4, M5?
Nylon spacers in the right length and diameter? Secured with UHU por?
These spacers are available in metal too!
Pics? Size comparison. What do you mean with grub screw? Is there a grub screw at the steering link?
Aug 23, 2019, 07:35 AM
Car Bashing
Jym73's Avatar
How can I extend the steering link ?? I got a xtraspeed titanium link and the threads are cut into the material...so no swap of the set(grub)srew... What can I do ...its missing almost 1 cm each side ??
Maybe with this "M3x10mm Female Threaded Standoff Spacer Brass Hex Coupling Nut" :
Description:
Image source : https://www.ebay.fr/itm/M3x10mm-Fema...oAAOSwfmldVApQ
You can find different sizes. You keep the grub screw in your xtraspeed titanium link and you add an other grub screw on the other side.
Aug 23, 2019, 08:22 AM
Yeah, that is what I have thought about. These spacers should be available made from aluminum too! I think rounded versions too, instead of the hex!
Aug 23, 2019, 10:38 AM
Car Bashing
Jym73's Avatar
Yes, we can find them in many different materials, here aluminum (more expensive too) :
Description:
https://www.ebay.fr/itm/SuleveA-A-E-...r/162588405917
Aug 23, 2019, 11:56 AM
Thanks you two...gave me the right idea
Aug 30, 2019, 11:25 AM
I have a issue! First time since 10 years I would say this one is a tricky one!
I have bought a Kanyon, the crawler version of the RH1046 with locked diffs! I want to make it faster and want to install unlocked diffs, for better performance in turns!
I have ordered two diff's, and received these ones:
Description:
It looks like they would fit!
Here is the problem! The axles, front and rear, of my Kanyon fit to the locked diffs! But for the unlocked diffs the axels need a gap to fit the splint to hold the gear!
Gap for trhe splint!
Description:
Axle from the Kanyon without the gap!
Description:
I have looked at both manuals (RH1046 and Kanyon), and both axles, front same as rear, are labeled the same!
How, or where can I get the front CVD and rear axle shafts from the RH1046 to mount the unlocked diff's to my Kanyon!
Aug 31, 2019, 01:36 AM
Car Bashing
Jym73's Avatar
If i remember well, when i locked my rear diff., is that it hasn't gap too. The rear axle is held by a "lips"/step on the other side on the axle which goes on a bearing and lock the axle in place.
EDIT : i just checked and yes, it is the "lips" on the other side of the axle which held the axle in place on the bearing.
The e-clip on those diff. isn't there to held the side gear in place in the diff. but to keep the drive cup in place (to avoid the drive cup to fall out), when on other diff. the drive cup is held by a pin which itself drive the gear.
On this kind of solid axle, it isn't possible to assemble the axle on the diff. before put the whole part in the main plastic axle. We must put the diff. inside the plastic axle first and then put the metal axle, so there is no way to put an e-clip.
Mini-Review FS Racing - Victory BL - 1/10 4WD Monster truck - Review Jym73 Off-road Cars 66 May 20, 2019 05:27 AM
Mini-Review SST - 1928V2 - 1/10 4WD Monster truck - Review Jym73 Off-road Cars 2 Feb 10, 2019 11:28 AM
New Product VRX Racing Sword XXX RH902 1/10 4WD RTR Truck fastmax Off-road Cars 1 Mar 11, 2017 05:02 PM
Discussion Hsp brontosaurus 94111 monster truck 1:10 4wd S3MKi Off-road Cars 0 Oct 06, 2015 03:56 PM
