Latency from Tx module PPM input to Nano Rx PPM output - RC Groups
Nov 18, 2017, 09:34 AM
Build more, websurf less
FlyingW's Avatar
Question
Jim,
Can you please estimate how much time passes from when:
Servo position information in a PPM frame output from a transmitter to the XPS Tx module comes out of a Nano Rx's PPM output.
I'm thinking some microseconds?
Paul
amount
Nov 18, 2017, 04:38 PM
It takes up 14ms to collect the data from the PPM stream before it can be sent via the transmitter. Sending the data over air takes under 1ms with 8 channels. The Nano decodes the packet after it arrives, so another 1ms before the servo positions are changed - which occurs in less than 2ms.
The longest delay in the entire process is the transmitter's frame rate.
Nov 19, 2017, 02:27 PM
FlyingW's Avatar
Interesting, about 17ms, with the majority of the time spent waiting for the complete frame to accumulate out of the transmitter. Thanks Jim, Paul.
Jan 07, 2018, 01:32 AM
John Hendry
CRSF with Frsky X7 issue
That's on the low end with Crossfire on a HORUS10 @ 19.5ms one test showed, and a lower line Spektrum TX at 41.5ms. Crossfire reduces latency on HORUS10 using CRSF (not PPM) almost in half due to its faster processing. But be aware current Frsky X7's have an issue that requires a hardware and software mod to get telemetry with CRSF working correctly. There is a software alone fix but it "works" by slowing down the data flow to 25% according to one site. Really have to do your homework as half of what is said is often half true half of the time. The dream of an amazing $200 radio with fast reflexes and long legs has been put on hold it seems until the next revision of the X7. Issues like this is where a manufacture needs to post information online to control the fallout and keep facts straight as for a lot of people this will be a non issue, but some will scream about it.
Jan 07, 2018, 01:49 AM
This thread is about a PPM data stream, which has nothing to do with FrSky transmitters.
Discussion EZUHF RX - PPM and PWM output? ArmChair_Ninja Multirotor Drone Talk 0 Feb 09, 2017 02:28 AM
Discussion Librepilot CC3D SBUS Input, PWM Output Rx Port cbcalhoun Multirotor Drone Electronics 1 Mar 20, 2016 02:56 PM
Discussion Eachine i6 tx - missing PPM output quadpent Beginner Multirotor Drones 2 Feb 22, 2016 04:21 PM
Question Futaba 10C, what Tx module and RC Rx do I need for PPM capable for a VortexPRO????? LexusFPV FPV Equipment 0 Dec 13, 2015 03:29 PM
Discussion Getting PPM output from a Spektrum RX without any PPM stage Arthur P. DIY Electronics 44 Apr 26, 2010 05:38 AM
