Stormbird Build Thread - Page 9 - RC Groups
Jan 16, 2018, 07:59 PM
IT'S NOSE HEAVY!!!!
cityevader's Avatar
Way back when i first got my Viking, i HATED it. It was many, many sessions over several months before it was dialed in and became my favorite plane ever (except for the slightly long 3m span).
Hang in there Miguel, and do yourself a favor and write down everything in a log...throws, cg, etc, documenting changes to prevent possible repeats of adjustments.
Jan 16, 2018, 10:44 PM
Building gliders aaagain...
LuckyStriiike's Avatar
Originally Posted by Doc James H
Hey Lucky, I think Miguel is far from having the right setup so far but having said that I'm sure he'll get it pretty fast.
Once the CG is in his preferred spot I'm sure the camber and reflex will all be coming.
By the way this section is VERY responsive to reflex.
I have a very scientific method of setting it up.
I put a rule or a straight edge at the back and raise the control surface until the rule touches the TE, then touches the wing surface forward of the hinge, and finally the the hinge itself - 3 points. By that time the TE will probably be reflexed about 1.5mm (1/16")
Works perfectly.
Doc.
Cool Thx
Feb 10, 2018, 09:02 PM
I have to say but for me 100mm is the right cg with elevator being in the neutral position and dive test being neutral.
Feb 20, 2018, 11:02 PM
Just starting to look for a slope plane... I see good deals on the schwing but it's retail is about the same as a storm bird. Can someone compare the planes.... should I take the soaringusa deal 30% off a schwing... or pay the 650 for a storm bird.... any thoughts?
Feb 20, 2018, 11:08 PM
For that price get Schwing
Feb 21, 2018, 02:32 AM
Morologus es
Doc James H's Avatar
Miguel is probably right there, Dave.
Schwing is a good allrounder and is larger than the Stormbird which will give it a bigger flight envelope at the low wind speed end.
Its slower but is more versatile to conditions.
Cheers,
Doc.
Feb 21, 2018, 06:20 AM
Slope P's Avatar
I love my Schwing.
Mar 26, 2018, 07:52 PM
I still haven't started building my Stormbird, but I got a Schwing Corsa kit from Wayne on Friday, built it over the weekend, and maidened it today (Monday). The only issue I had was that I didn't add quite enough nose weight (nose tucks down in a dive).
The two are very close in design, with just the much bigger wings on the Corsa. The flight characteristics of the Corsa are really nice, precise, smooth and it doesn't bounce around at all.
Mar 27, 2018, 03:29 AM
Morologus es
I think you will find the Stormbird a tad more responsive and agile but the 'Corsa is no slouch.
Doc J.
Apr 16, 2018, 03:18 PM
I finally built my Stormbird. The romier fuselage was much easier to work in than the Schwing.
I maidened it Sunday at Coyote HIlls in 32 mph winds and it was great!
For the first flight, I put the CG at 95mm, and I'm going to be moving it back more. It still zooms more than I like in a dive and takes a fair amount of down elevator when inverted.
Apr 16, 2018, 04:50 PM
Exactly, its not entirely cured at 100mm but becomes better.
Discussion Stormbird - the New Typhoon is here. Doc James H Slope 10 Feb 03, 2018 06:28 PM
Discussion Successful Build Thread - add your build - Search for info about builds mike_kelly Beginner Multirotor Drones 12 Mar 15, 2017 09:31 AM
Contest Fifty plus build off - Started 1/4/2016. Build Off Ended - POLL THREAD OPEN!! Sundancer Vintage & Old-Timer Designs 372 Oct 01, 2016 07:42 AM
Build Log Wally Builds A Blue Beast - CLOSING THIS BUILD THREAD: THANKS FOR THE SUPPORT wadasczi Sailplane Talk 48 Aug 01, 2016 08:44 AM
Question Should the build instructions for my plane go in a build thread or in my blog? Lance Nordby Sport Planes 5 Dec 25, 2015 06:48 PM
