This thread is privately moderated by phil alvirez, who may elect to delete unwanted replies.
Nov 16, 2017, 04:59 AM
testing new cells (batteries) from micro motor warehouse
learned about these cells for umx planes similar to the radian:
https://micro-motor-warehouse.com/co...eid=4db1759bcc
eventually finished performing tests on these batteries. just in time for fall to arrive with winds and rain
i used the hobby king nano cells for comparison https://hobbyking.com/en_us/turnigy-...kzone-etc.html
1st did bench tests using a umxradian and running the motor at half throttle (stick vertical) while holding the plane on my hand, and stopping every 30 seconds and taking readings of the voltage remaining.
umx radian: https://www.rcgroups.com/forums/show...0mm-Version%29
i used the hobby king cell 160 mah as a point of comparison:
and the 1st 1 from micro motor is this: https://micro-motor-warehouse.com/co.../mylipo-150mah
the way i did the bench tests was installing the cell in the umx radian and run the motor at half throttle (stick vertical) for 30 seconds, stop and measure volts. then again. until reached the minimum recommended.
time and volts
seconds--------30------60------90-----120------150-------180-------210-----240------270------300-------330------360-----390------420---450---480
1: hk 160-----405----395----389-----384------380-------377-------374-----371------368------365-------359------345
2-150/25c----408----396----391-----385------381-------378-------375------373------369-----365-------353------312
3-150/45c----409----399----393-----388------383-------379-------377------373------371-----368-------356------335
4-my15025c-409----400----394------388------384-------380-------377------375------373-----369-------365------333
5-my17525c-409----402----395------391------387-------383-------380------377------374-----374-------373------370----367------355-----322
6-my20525c-415----406----400------395------392-------388-------385------383------380-----379-------375------374----373------372-----370-369
7-tw205-------423----412----404-----395------391-------386-------382------380-------372
8-tw255-------431----423----416-----406------399-------392-------388------384-------382-----378-------375
more power at launching
i must add that with all these cells there is a big increase in power at launching. to the point that sometimes the esc turned the radio off so must be careful.
just dont move the throttle all the way up at launching for the 1st flight with that cell.
so much power!
adapter
by the way, i made a connector to use the large connectors that come with the largest cells.
i used this piece: https://micro-motor-warehouse.com/co...ble-jst-ph-2-0
i removed a connector from a dead cell from hobby king and soldered it to this.
Can I make a battery using NiCd cells from drill battery? TheB33st Batteries and Chargers 12 Nov 28, 2017 09:56 AM
testing new cells (batteries) from micro motor warehouse phil alvirez Batteries and Chargers 10 Nov 06, 2017 05:12 PM
How to make a 6 cell battery from two 3 cells The Valkman Batteries and Chargers 0 Mar 21, 2017 10:44 AM
Tested the LIFEPO4 800 mahr cells from Battery Space. cyclops2 Batteries and Chargers 12 Nov 23, 2010 08:00 PM
Test of new 50C !!!! cells from BMZ Kraeuterbutter Batteries and Chargers 54 Nov 28, 2004 08:49 PM
