Feb 10, 2018, 06:18 AM
Hi Chris.
Sorry to hear of your issues. I think your original problem may have been head plate which was preventing the blades coning enough under load. . I use the double plate Steve described on this size of model and at rest the blades droop more than yours in the previous photos which could mean your plate is much stiffer. In fact I use a round plate which just touches the 3 edges of the main plate bolted underneath the main ones to limit the downward droop and stop blade strikes. By reducing the disk area on your last flight you are effectively making the plate even stiffer but compensating by a heavier nose at which point you ran out of back stick. You may therefore find that going back to the original setup just provides the nose up motion again. I would either make a more flexible plate or make the head plate out of existing material but make it bigger. More blade tip weight could also help here. Other thing I have found is that plates of polyester glass fibre are more flexible than epoxy glass and react differently. .
Like you I have spent many hours experimenting and one of my original gyros (cooler) was rebuilt 8 times before I got it to fly.
Sorry to ramble but I know how frustrating this is.
Keep going
Graham
Feb 10, 2018, 08:58 AM
106flyer's Avatar
I agree, the blade size maybe should be matched to the model weight but plate flex is critical ... too stiff on my Whippit was a disaster
Pm your address to me Chris and we will send you some presents
Steve
Feb 10, 2018, 07:18 PM
britinoz's Avatar
Thank's again for your input gent's silly old fart like me needs all the help he can get these days.
It never crossed my mind to fact that you would be using any other than epoxy board...but the simple fact is that manufactures would find it just to costly.
Good news is that I was able to get the PA-36 up and flying after its prang and I was using a very small disc that I did not expect to fly . so more testing soon I hope ..but we are going through some pretty hot conditions at the moment and just to hot to get out in the sun.
Steve ...PM sent present for me ? .... that must be my late 73 birthday present.
Happy Landings
Chris...
Feb 11, 2018, 10:22 AM
106flyer's Avatar
No problem Chris.. I will get Tim to 3D print you a head too and you can give it a try
Steve
Feb 12, 2018, 06:12 PM
britinoz's Avatar
Wow That sound great to me ...thank 's a lot.
Chris...
Feb 13, 2018, 07:20 AM
106flyer's Avatar
Sure no problem will get 2 sets made :
1 triangular plate 0.8mm & 1 at 0.4mm with 0.8mm circular anti strike plate
Hope it helps
Steve
Feb 13, 2018, 10:04 PM
britinoz's Avatar
That I should have such a friend....................
Feb 14, 2018, 04:08 PM
106flyer's Avatar
Here you go Chris ... one their way..
Steve
Feb 15, 2018, 03:57 AM
britinoz's Avatar
SOOOOOO
I wonder who has just become my "second best friend".
Happy Landings
Chris...
Feb 17, 2018, 03:15 PM
106flyer's Avatar
Package on its way Chris
Steve
Feb 17, 2018, 03:30 PM
BigTradioman's Avatar
Be careful Chris, we may all just turn up for a GyroNut fly in. Ha ha ha. I could do with a bit of sun on my back right now. The missus is just getting over the Aussie flu. Ran me ragged for a week.
Feb 17, 2018, 07:12 PM
britinoz's Avatar
Aussie flu ??? ...never come across that one down here...we get Asian flu in this part of the world.
Feb 18, 2018, 10:56 AM
106flyer's Avatar
Yep apparently if you get it you are not sure which way is up !!!! Ha ha !!
Steve
Feb 18, 2018, 06:56 PM
britinoz's Avatar
000
Mar 06, 2018, 09:10 PM
britinoz's Avatar
Post man came today......
Nice looking parts..... make my ones look as if they were carved out by a cave man.
Steve...I appreciate you kindness...I really do ...Now considering that I am using the same size blades as you...what is you recommendation for discs.Should I use all three or just the round disc and the thick one.
Chris...
Discussion Rotorshape Cierva C30 anyone? EricClark Auto Gyros 127 Aug 30, 2012 06:30 PM
Discussion Help with a C30 Cievra hirpm Auto Gyros 2 Sep 18, 2008 08:38 AM
Discussion My new C30 fradequero Auto Gyros 2 May 27, 2008 11:11 AM
Discussion LAheli C30 Kit. XE521 Auto Gyros 36 Nov 07, 2007 09:35 PM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
