Nov 10, 2020, 12:37 PM
BigTradioman's Avatar
Very successful maiden today in my COVID Secure private no public access field. Very stable model. I need to add a bit of shim as the blades are too lifty, bigger wheels for winter as the ground is rough, and I don’t like my colour scheme much so need to add a bit of white. Nothing wrong with the model though.
Nov 21, 2020, 04:29 AM
106flyer's Avatar
Knew you would enjoy . Very stable in all winds
Steve
Nov 30, 2020, 04:01 PM
Hi All !!
How and where do you check correct hanging angle.? Undertand hanging from the head, but ... Horizontal tail surface from table or mast shaft from vertical.?? Both are the same only if mast is perpendicular to stabilizer ....
Thanks...!
Dec 02, 2020, 04:36 AM
Originally Posted by Lewta
Hi All !!
Thanks...!
Hang the model in ready to fly state with blades extended from the Jesus nut, spindle. The angle is between the thrust line and horizontal so you could use the stab. The model is very tolerant but I would start at 15/18 degrees then adjust after test flight
Dec 02, 2020, 01:32 PM
Thanks BigTradioman !
Oct 16, 2021, 04:13 AM
Also known as simon_t
en_spt's Avatar
John Greenfield’s C30. I was very impressed with the way this model flew, to the extent that I’m starting to gather bits and ideas, including a visit to Coolwind’s website…. John is planning two bigger versions. As an LMA member, the largest might be quite big!
Simon
Nov 27, 2021, 10:19 AM
en_spt's Avatar
Having been motivated see John Greenfield’s C30 flying, mine is nearing completion. A club member is printing the radial engine for me, and I need to sort the fairings for the undercarriage legs. Sadly the weather has been poor for a little while, and looks set to continue in that vein for a while, so it is not clear when the maiden will take place.
Simon
Dec 01, 2021, 05:00 AM
Simon
Simple fairings are made from plastic A4 spine bindings cut to size and hot glued on. Plenty of colours on Amazon and eBay
Dec 01, 2021, 10:22 AM
en_spt's Avatar
I ended up using some balsa trailing edge stock, carved to an airfoil section. On the main undercarriage legs I formed and soldered some thin brass plate and the fairings are secured to these using thin double sided servo tape
Dec 03, 2021, 07:15 PM
en_spt's Avatar
Managed to find a short weather window to complete maiden flight and two further flights. Everything went well, and I am very pleased with the handling. Other than a little left rudder trim, and a couple of clicks of left cyclic, it flies hands off. The sound of the the blades chirping is wonderful, and I found it easy to chuck it around at low level with confidence. I was on my own at the field, and it was late in the day and a bit gloomy, but I managed to prop my iphone up and capture some video. It needs a bit of editing, but here is the raw version:
C30 Autogiro first flights (4 min 53 sec)
Simon
Dec 03, 2021, 08:32 PM
britinoz's Avatar
Well Simon ,you seem to that your model trimmed out pretty good and put on quite a show for us. I hope this may generate further interest in building and flying more autogyros.
Happy landings
Chris...
Dec 04, 2021, 03:41 AM
@Simon beautiful precision flyer. Nice!
PS Is there any reason why it is not possible to leave a comment underneath the video? Probably you unintentionaly left the video checkmarked for kids?
Dec 04, 2021, 05:11 AM
en_spt's Avatar
It’s been a long time since I uploaded to YouTube, so I assumed that setting meant ‘suitable for all’ - I have removed that restriction so hopefully commenting is available now.
Simon
Dec 11, 2021, 08:43 AM
en_spt's Avatar
Got the 3D printed radial assembled, painted and fitted to my C30, and today after days of strong winds the wind was just right, and I was able to get another 5 flights in - The hang angle was slightly better with the weight of the radial on the front, and other than needing to fly around on a slightly higher throttle, the model behaved just as well as the first flights. This was the first time that I have flown it with fellow club members at the field, and they were all fascinated and impressed by it’s looks and the way it flies. With a bit of breeze today it was possible to do servo speed landings. Such a good design!
Simon
Dec 11, 2021, 07:46 PM
britinoz's Avatar
That radial certainly sets the model off. I'm using a similar one on a model.
Chris...
Discussion Rotorshape Cierva C30 anyone? EricClark Auto Gyros 127 Aug 30, 2012 06:30 PM
Discussion Help with a C30 Cievra hirpm Auto Gyros 2 Sep 18, 2008 08:38 AM
Discussion My new C30 fradequero Auto Gyros 2 May 27, 2008 11:11 AM
Discussion LAheli C30 Kit. XE521 Auto Gyros 36 Nov 07, 2007 09:35 PM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
