Nov 15, 2017, 02:33 PM
106flyer's Avatar
Build Log
C30 EPP Autogyro
Worked out ok
Nov 15, 2017, 07:20 PM
britinoz's Avatar
Now that is what I call a good looking model... well done Steve.
Happy Landings
Chris...
Nov 16, 2017, 06:12 AM
PaulB's Avatar
Originally Posted by 106flyer
Worked out ok
Just a slight understatement IMHO, I would swap OK for outstanding
Latest blog entry: Just To Say Hello.......
Nov 16, 2017, 02:45 PM
106flyer's Avatar
SJ C30 Autogyro maiden (2 min 7 sec)
Nov 18, 2017, 06:43 AM
Again a great effort. This one has got to go on my build list if there will be any plans available. What size blades did you work with in the video?
Graham
Nov 19, 2017, 07:58 PM
britinoz's Avatar
Steve ignore PM ...All OK
Chris...
Nov 20, 2017, 04:10 PM
106flyer's Avatar
Power setup:
Servos Corona 238 mg, 40amp esc, motor 3536 1450kv , battery 3s 2200mah, prop 10x 6EE
Blades are 10mm leading edge spruce with 4" 6mm sheet split into 2 giving blade width approx 61mm. 5gms of tip weight. Bolt hole at 513mm from tip with 15deg root angle
Head plate is Graham's suggestion of 0.8mm Whippit size with additional 0.4mm plate giving increased stiffness
Hang angle 16 degrees
Plan now available on download site on Coolwind.co.uk - enjoy
No money taken or made from this ... in case anyone thinks so
Reward is anyone's enjoyment , pics or videos
Steve
Nov 22, 2017, 03:39 AM
britinoz's Avatar
Steve
I was wrong (as usual) about the 238's I found a heap of sellers on ebay "in transit"
and Banggood have the motors and props in stock.
And the game is a foot..............
Chris...
Nov 24, 2017, 09:13 PM
britinoz's Avatar
Steve
Did you intend to post a build of this model ?
Chris...
Nov 25, 2017, 03:29 AM
106flyer's Avatar
Hi Chris, did not take pics along the way for this and the KA1. Build is straight forward we hope from the plan in the ' make it up as you go style !!'.
If anyone gets stuck or is not sure will happy answer any questions and take and post extra pics to help.
Only tricky bit is the 3D printed engine which Tim drew and printed for them both . If not for that I would have made from foam or wood
Steve
Nov 29, 2017, 06:05 PM
britinoz's Avatar
Steve.
What is the weight of the fuz with all electrics ..no rotor ..no lipo ?
Chris...
Dec 01, 2017, 04:03 PM
106flyer's Avatar
Hi Chris , sorry for slow reply. Weights are:
Battery 2200 3s - 190g
Blades and head plates - 180g
Model less battery and head/ blades - 790g
Model length from prop line to end of rudder 810mm
Steve
Dec 03, 2017, 01:40 PM
106flyer's Avatar
Second one coming along ok, some pics this time during construction
Under carriage this time down sized on rear legs to 2mm , main still 3mm
Steve
Dec 03, 2017, 01:48 PM
106flyer's Avatar
A little shaping ..
Dec 03, 2017, 01:50 PM
106flyer's Avatar
Now for the sharp end ... power plant upgrade I think .. All Tim's work ,
Discussion Rotorshape Cierva C30 anyone? EricClark Auto Gyros 127 Aug 30, 2012 06:30 PM
Discussion Help with a C30 Cievra hirpm Auto Gyros 2 Sep 18, 2008 08:38 AM
Discussion My new C30 fradequero Auto Gyros 2 May 27, 2008 11:11 AM
Discussion LAheli C30 Kit. XE521 Auto Gyros 36 Nov 07, 2007 09:35 PM
Problem with GP Electrifly C30 ESC Steph280 Electric Plane Talk 6 May 15, 2001 05:07 PM
