Skywalker SMART FPV Twin Wing
The Skywalker SMART is a twin motor powered FPV wing from FPV Model, and has room inside for all your FPV gear.
Available From FPV Model
The Skywalker name continues for FPV-based fixed-wing aircraft with the new SMART EPO wing. The Skywalker SMART is a twin motor flying wing with a 39" (996mm) wingspan and is setup for a pair of 2206 2300kv motors and 30a escs. Power comes from a 4s 1500-3300mah lipo battery that mounts in the center fuselage of the SMART. There seems to be a decent amount of room inside for the battery, along with a dedicated spot for a multirotor-sized flight controller. The esc's are mounted on each motor pod to maximize cooling and save space. Up front, there's room for an FPV camera and HD camera in the nose.
The Skywalker SMART is available from FPV Model and retails for $59.99.
CLICK HERE for more information.
Specifications:
  • Wing span: 996mm
  • Fuselage length: 430mm
  • Wing area: 25.9m2
  • C.G.: From head to back 240-250mm
  • Flying weight: 750g-1000g
  • Takeoff:Hand cast
  • Landing: Belly Landing
  • Air speed: 60km/h
  • Maximum flying time: 30min
  • Motor: 2206kv2300*2pcs
  • ESC: 30A*2pcs
  • Servos: 12g*2pcs
  • Propeller: 5045E/ep*2pcs
  • Battery:4s 1500-3300mah
  • Radio: 3CH 2Servos
Nov 16, 2017, 09:11 AM
USA: LakeGeorge, New York
Matt,
Did you get a free sample and flown it?
Counter-rotation props?
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Nov 16, 2017, 09:20 AM
www.gunnphotoservices.com
Matt Gunn's Avatar
Originally Posted by rclab1
Matt,
I don't have one, I just put together a news story.
But judging by the pic showing the props, they are indeed counter-rotating.
Latest blog entry: www.gunnphotoservices.com
Nov 16, 2017, 10:51 AM
mike_o's Avatar
Interesting. Had I been the designer, I'd probably have extended the motors/nacelles backward and put the vertical stabilizers on there instead of on the wingtips, where they tend to get caught up in something all the time
Nov 19, 2017, 09:01 AM
Running jokes into the ground
b-29er's Avatar
Looks neat, is this supposed to be a racer, intermediate range fpv, or both?
Nov 25, 2017, 02:03 AM
Ellen Zhu
Skywalker Smart is integrated racing with FPV aircraft. We still sell PNP version, if you use that configuration, it could reach 130KM/H.
Dec 13, 2017, 01:34 AM
Thank you Matt. We have just made a short flying video:
Skywalker Smart Flying Wing vs Feather X210 Racing Quad (1 min 34 sec)
Dec 13, 2017, 09:14 AM
kuiperJ's Avatar
So are the two motors for differential thrust?
Say you start to waggle on the yaw axis, the computer (SMART) kicks on and buffers out the waggle thus holding firmer yaw authority maybe?
Dec 14, 2017, 03:36 AM
mike_o's Avatar
I haven't seen anything that indicate that is the case. But I expect that it would be easy to do with iNav on a cheap F3 controller.
Dec 14, 2017, 10:33 AM
kuiperJ's Avatar
So is the function of the two motors for "cool factor" or does it serve some kind of a engineering/performance advantage?
Dec 14, 2017, 01:03 PM
mike_o's Avatar
I would assume it to be a combination of "Cool factor" and engineering/performance advantage:
- Smaller prop less prone to break on belly landing allowing central thrust line
- Dual counter rotating props cancel out torque roll on launch
This works very well on my twin motor mod Skyfun:
TwinFun FPV (1 min 25 sec)
I haven't seen any useful application of a diff thrust set-up, apart from on a TwinStar that was able to maneuver on a frozen lake (but not frozen enough to walk on)
Dec 20, 2017, 09:25 PM
Ellen Zhu
Skywalker Smart Crossing Bridge
Skywalker SMART Crossing bridge (3 min 32 sec)
Dec 29, 2017, 08:17 PM
Hey that looks pretty sweet. I eventually want something with 2 motors for redundancy and this looks great for the price.
New Product Skywalker WALL-E2000 2030mm Twin Motor FPV Plane mike_o FPV Aircraft 295 Jun 23, 2018 04:28 AM
New Product Skywalker SMART 996mm Wingspan EPO FPV Flying Wing FPV.Model FPV Aircraft 5 Dec 13, 2017 01:39 AM
New Product Skywalker SMART 996mm Wingspan EPO FPV Flying Wing RC Airplane KIT smg24 Banggood.com 0 Nov 13, 2017 10:16 AM
Discussion Best FPV Platform : Skywalker V5 vs Skywalker X8 Wing asaak FPV Talk 15 Oct 22, 2016 02:19 AM
Discussion skywalker 1900 wings as FPV Wing asaak Flying Wings 0 Jan 30, 2014 06:04 AM
