Nov 14, 2017, 04:54 AM
New Product
KISS FCv2F7 / New Flyduino 32bit Flightcontroller
The Idea was to get the simple KISS FC to the next level and due to intensive long term tests of some pretty good Pilots we were able to optimize the code to a point where you hopefully get your quad in the air quite quick.
Normally you just need to choose your Airframe in the GUI and you are able to fly (at least with KISS ESC), otherwise you can download presets of well known pilots for given configurations.
And of course you can tweak the PID yourself through the GUI.
Technical data
  • STM32F722RET6 MCU, ARM-Cortex M7 with FPU running at 216Mhz
  • MPU6000 Gyro and ACC Sensor
  • Integrated DCDC converter for direct LiPo battery input (2-6S 6-30V) max 500mA on 5V
  • The first four ESC outputs are amplifyed to 5V Signal with very fast drivers (for a clear Dshot signal)
  • CP2102 USB-UART USB controller for simpler updates with the KISS Bootloader
  • MCU: STM32F722RET6 @216Mhz
  • Weight: 5g
  • Mounting Holes: 3x3cm pattern with 3.3mm holes (compatible with most frame types
  • Voltage: 2-6S (direct)
Available at Flyduino now
Download Manuals (en/de) here
Connection Plan by Philipp Seidel
KISS FCv2 FAQ in our knowledge base
In some cases - especially Mac users - might need to download the drivers for the CP2102 UART/USB
https://www.silabs.com/products/deve...ge-vcp-drivers
NOTE: If you use a Mr. Steele PDB make sure to connect the correct ports!
KISS FC V2 - Freestyle testing (2 min 24 sec)
Always something new (Frame, FC, Esc's) (3 min 20 sec)
dcl quad los | astrox truexs proto f40III 2600kv 5x4.8x3 hqprop kiss esc proto fc proto 4s1550 95c (2 min 25 sec)
Ripping a 400 Years Old Fortress (3 min 1 sec)
FPV Autumn (3 min 14 sec)
KISS FC V2 KISS ESC 32a Dshot2400 - Maiden flight - FPV Racing Test (0 min 51 sec)
no songs and FPV Freestyle (2 min 56 sec)
Nov 14, 2017, 05:06 AM
Welcome to 2015.....
Nov 14, 2017, 05:57 AM
you might know that we where the first ones with a AIO (that has four ESC's and a FC onboard) on the market in 2016... so you might see we did the FCv2 like it is because we want it to be like that
regards
Felix
Nov 14, 2017, 06:04 AM
Then better hurry up and release the 4in1 ESC quickly before the competition takes over.
Nov 14, 2017, 06:15 AM
So you really want to build a stack with pdb, 4in1 esc and Fc? No way thats freakin outdated oldschool.
Nov 14, 2017, 06:44 AM
bra1nphuk's Avatar
So, what’s the advantage over the V1?
Nov 14, 2017, 06:54 AM
What is landing :O
So a total of 5 UARTS ? Rx4 and Tx4 is also usable right ?
Too expensive for me, but time will tell how well it does
Nov 14, 2017, 06:58 AM
F7 FPU, MPU6000 via SPI, DS2400, 6s, CP2102, more UARTs, better layout...
Nov 14, 2017, 07:12 AM
raumagent's Avatar
Why did you kept the Rx pins in the front when on the majority of all frames the Rx is usually mounted behind the FC?
Nov 14, 2017, 07:15 AM
FedorComander's Avatar
i think mostly for compatibility with v1?
Nov 14, 2017, 07:26 AM
raumagent's Avatar
Backward compatibility is nice but if you only release new products every few years this would have been the chance to pull a few things straight.
BTW, I'm not trying to bash here, I'm just trying to understand some decisions Flyduino has made with their new FC.
Nov 14, 2017, 07:30 AM
raumagent's Avatar
Also, like I wrote in the KISS FC v1 thread, I'm usually not the one to complain about prices but 185,- Euro for a full KISS setup is just insane. And most of us need more than only one setup.
Nov 14, 2017, 07:49 AM
well i like it...
only a bit pissed no data chip... would be handy for logging.
a well 8 blue leds hehe love it
Nov 14, 2017, 08:22 AM
Originally Posted by Jdm1983
well i like it...
i used those chips. its real PITA...
Nov 14, 2017, 08:26 AM
raumagent's Avatar
But why no onboard SD card slot then?
New Product KISS FCv1 / Flyduino 32bit Flightcontroller flyduino Multirotor Drone Electronics 26852 Jan 01, 2019 09:03 PM
New Product KISS ESC 24A Race Edition / Flyduino 32bit ESC flyduino Multirotor Drone Electronics 4880 Dec 01, 2018 04:41 PM
New Product KISS ESC 30A 2-6S LiPo from Flyduino juuuut Multirotor Drone Electronics 489 Mar 18, 2018 11:59 AM
New Product Alexmos BaseCam 3axis 32bit Brushless Gimbal Controller by Viacopter & Flyduino kinderkram Multirotor Drone Electronics 3087 Sep 02, 2017 03:38 AM
