Nov 30, 2017, 11:06 AM
An Original!
Gliderguy's Avatar
Just received my Easy Glider4 kit. Kind of excited, it looks like MPX has done a very nice job of designing and implementing this plane. A far cry from my experience with foamies of the distant past.
One question on the CA. Does the Foam Tac give you any more working time to get parts in place before it sets up? I worry a little about getting the fuse halves misaligned if the glue sets up too quick.
Mostly looks like a fun assembly though. Looks like I will be using a Emax GT2215/09 1180kV Brushless Motor. I'll use a Turnigy Plush 40amp ESC and a Zippy Compact 2200mAh 3S 11.1V 25C 35C Lipo. Seems like that should be about the right sized power system.
Nov 30, 2017, 01:49 PM
USA: LakeGeorge, New York
Foam tac gives you about 45sec to align right.
So its good time
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Nov 30, 2017, 02:15 PM
Xpress..'s Avatar
FoamTac won't give you any more working time than Medium CA. The Multiplex airplanes are designed to key together quickly so there shouldn't be much worry about whether parts will align or not.
Also, the Multiplex ROXXY power system is available and will fit the airplane perfectly:
http://www.weekenderwarehouse.com/ea...-4-power-pack/
Nov 30, 2017, 09:03 PM
An Original!
Gliderguy's Avatar
Ok, I'll use the medium CA on the fuse. I've been using it for the other parts and it does take a little while to set up so I should be good to go.
Dec 01, 2017, 11:53 AM
Xpress..'s Avatar
A small bead is all you need, I sometimes like to take a piece of wax paper (or the backing paper for a sticker) and use that as a spreading tool to evenly spread the CA out so that there is a nice even sized bead along the glue joint. It also helps minimize seepage when you press the parts together.
Dec 02, 2017, 10:03 PM
An Original!
Gliderguy's Avatar
OK, now that I've rediscovered my allergy to regular CA, what else would anyone suggest to use as a glue for this plane?
Dec 02, 2017, 10:20 PM
RCG Admin
Jason Cole's Avatar
Foam Tac is a solid choice.
Dec 02, 2017, 10:57 PM
An Original!
Gliderguy's Avatar
OK . Is this kinda like foam safe CA? I don't seem to be affected by that product.
Dec 02, 2017, 11:27 PM
RCG Admin
Jason Cole's Avatar
No it’s a contact adhesive. Completely different from CA, but you’ll love the stuff.
Dec 03, 2017, 12:24 AM
An Original!
Gliderguy's Avatar
Great!
Just bought a bottle. Thanks!
Dec 04, 2017, 04:04 PM
Xpress..'s Avatar
FoamTac is great stuff. Again, you don't need a big bead, just enough to get the job done.
Dec 05, 2017, 04:02 PM
An Original!
Gliderguy's Avatar
So, I suspect you just apply it to one surface and not to both. And does it setup right away or do you need to clamp it or tape it for a while? I suppose it will say on the label.
Dec 05, 2017, 04:27 PM
Xpress..'s Avatar
The instructions are pretty simple:
1. Apply a small bead to one surface
2. Place both surfaces together and press
3. Immediately separate and wait a handful of seconds.
4. Place surfaces together and press firmly, the bond should be strong enough to hold them together until it fully cures.
Dec 05, 2017, 04:30 PM
Foam Tac
Foam Tac & Foam Fill Product Review | RC Hobby Network (5 min 46 sec)
Dec 05, 2017, 08:41 PM
An Original!
Gliderguy's Avatar
Wow, thanks. Looks like cool stuff.
Review Multiplex Heron High Performance RR Electric Sailplane Review Michael Heer Electric Sailplanes 124 Jan 16, 2019 11:16 AM
News New Multiplex EasyGlider 4 Jason Cole Electric Sailplanes 60 Nov 20, 2018 05:56 AM
Article Multiplex Cularis Electric ARF Sailplane Review Michael Heer Electric Sailplanes 78 Nov 08, 2018 08:32 PM
Review Multiplex FunGlider Electric Sailplane Review Jason Cole Electric Sailplanes 25 Oct 25, 2018 11:11 AM
Article Multiplex Merlin Electric Powered Sailplane Review Michael Heer Electric Sailplanes 116 Dec 11, 2017 10:23 PM
