Bohemia Models “1928 Monocoupe" - RC Groups
Nov 10, 2017, 09:27 PM
AMA# SIMAGES
simages's Avatar
Build Log
1 of 2 latest projects........ I picked up this never flown RTF at the 2017 NEAT Fair.
Electric conversion by: Greg Covey | Article Published: June 2003
• • History Overview • •
The Monocoupe 22, the prototype of the 70, was the first light cabin monoplane to be certificated under the Department of Commerce regulations established in 1927. In 1928, nearly 90 percent of all the light airplanes produced and sold in the United States were Monocoupes. The popularity of this light cabin plane lay in the side-by-side seating and the pleasant, though spirited, characteristics of the aircraft that made it fun to fly.
• • Specifications • •
Recommended Flying Site: Flying Field
Airframe Type: Sport
Pilot Skill Level: Intermediate
Builders Skill Level: Intermediate
• RTF Weight: 10lbs / 160oz
• Wing Span: 82 in
• Wing Area: 1054 sq in
• Length: 50 in`
• Loading: 21.9 oz sq ft
• Wing Cube loading:
• • Power • •
• Engine: Saito FA90R3 / FG19 KELEO Exhaust
• Onboard Glow Driver: ElectroDynamics 1.2v
• Propeller: 12x7 - 13x6 - 13x7
•Batteries: 9000mAh 1.2v Nicad and 6v NiMH
• • Control • •
• Control Layout: 7 Channels - R/E/A/A/F/F/T
• Aileron Servos: 2 x Futaba S3152
• Elevator Servo: 1 x Futaba S3152
• Rudder Servo: 1 x Futaba S3152
• Flap Servos: 2 x Futaba S3152
• Throttle Servo: 1 x Futaba S3004
• Receiver: Spektrum AR7350 AS3X
Nov 11, 2017, 12:45 AM
AMA# SIMAGES
simages's Avatar
Wing servo plug mod.....
Secured the wing servo plugs with mount from a Multiplex FunCub XL.
Replaced all the control surface servos with S3152 and kept the S3004 on the throttle.
Nov 11, 2017, 12:53 AM
AMA# SIMAGES
simages's Avatar
Wing strut pins
I made a couple of pins to secure the wing struts.
Nov 11, 2017, 01:01 AM
AMA# SIMAGES
simages's Avatar
Replaced orininal wing eyelets
The original eyelets are really too short so I replaced them with thicker and longer ones. Each wing now has an added set screw on each side.
Nov 11, 2017, 08:34 AM
AMA# SIMAGES
simages's Avatar
Engine exhaust
Installed a FG19 KELEO Exhaust
Nov 11, 2017, 06:58 PM
AMA# SIMAGES
simages's Avatar
Quick fix..... ugh....
Hope it's last time to drop the engine for awhile. Had a bad glow plug wire.
Discussion Seagull Models Monocoupe 110 JEFF T Giant Scale Airplanes 26 Dec 16, 2016 12:17 AM
Build Log AeroGraphics 1928 Velie Monocoupe bshultz327 Free Flight 2 Sep 27, 2015 05:56 PM
Help! 1928 monocoupe 22 plans Gravy Scale Kit/Scratch Built 3 Mar 21, 2006 03:32 AM
Fiesler Storch- Bohemia Models Clayton Scale Kit/Scratch Built 14 Sep 18, 2002 07:39 PM
