Matek F405-AIO is the worst FC I bought - RC Groups
Nov 10, 2017, 08:12 PM
I just wanted to share my experience for people who might consider Matek FC.
So far I bought about 20 F3/F4 FCs and Matek F405-AIO is the worst and the first which I regret purchasing.
I have tried various methods of soft mount in the past but now I don't bother with soft mount not because it is ineffective but just hard mount is good enough even with PT1 and disabled gyro notch filter1 & 2.
So I built the new quad in such a way and what happened after is really frustrating.
At first flight there was terrible mid throttle oscillation in the range of 45~60% throttle. I could see it in the FPV display and could hear props twitching loudly. Luckily I never had mid throttle oscillation before!
The quad was quiet when just armed on floor without air mode. But as soon as air mode was turned on, it made scary attacking noise and almost jumped randomly due to too much sensitive/noisy gyro.
First remedy was to soft mount FC and then motors. Each step made the vibration reduced quite a bit but not good enough at all.
Finally after fiddling with Betaflight fliters, I had to reenable all of filters - Dynamic Filter, BIQUAD, notch 1 & 2.
Now it is as quiet in airmode on floor as other quads with hard mount and PT1/disabled notch.
This is the only FC that I regret buying and I would never buy Matek FC again although I had no problem with their PDBs.
Nov 10, 2017, 08:18 PM
I know Joshua Bardwell mentioned in his video that Matek F405-AIO is known to have very sensitive gyro issue but F405 don't. So F405 could be ok. I just didn't expect the issue to be mine as well.
Dec 22, 2017, 11:21 PM
quadfly51's Avatar
is this the one you tried out? i was thinking to buy it
https://www.banggood.com/Matek-Syste...r_warehouse=CN
i've used their PDB's and led strips with no issues
Dec 23, 2017, 06:53 AM
SadLeprechaun's Avatar
Doing a build with this tonight, I will report findings for you here. I am a soft-mounting master, can tune quads pretty well, and am addicted to caps, we shall see.
Dec 23, 2017, 10:11 AM
quadfly51's Avatar
thanks its good to have more input
Dec 23, 2017, 11:10 AM
I have used the F405-AIO for...about 3 moths, maybe more. Mine work just fine. You just have to softmount the FC and the motors. And having good quality motors that run smooth ofc. Also if your ESCs are "noisy" the FC might freek out after punchouts on 5S & 6S. I added a 1000uf cap to the power lead and all is well now. It is a "needy" FC, no doubt, but still packs a ton of features and is cheap, so I can't complain.
Dec 23, 2017, 08:52 PM
quadfly51's Avatar
it comes with rubber/silicone grommets . did you do/add anything
else ?
also included 4--35V/470uF - Low ESR caps for the ESC's
New Product Matek Flight Controller F405-AIO Dutch 79 Multirotor Drone Electronics 682 May 21, 2018 10:36 AM
Discussion MATEK SYSTEMS false advertising F405 AIO FC tobydogs Vendor Talk 5 Jan 02, 2018 07:27 PM
New Product Matek F405 AIO// Review and Noise Testing Drone Mesh Multirotor Drone Electronics 0 Jul 09, 2017 07:01 PM
New Product Matek BetaFlight F405-AIO Flight Controller, Built-in PDB, Dual Bec, OSD, 5 Uarts Livershifter Banggood.com 0 Jun 30, 2017 12:02 AM
