Nov 10, 2017, 05:45 PM
SPF3 flashes, connects to Betaflight, Cleanflight - but not INAV
Hi
Tearing my hair out about this. I've bought an SPF3 with a view to playing with GPS on a quad. I can get it to flash and connect to Betaflight and Cleanflight but absolutely not to INAV. By putting it in bootloader mode, I've managed to flash it with INAV, but it won't connect afterwards - it does the 10s timeout.
I've got the latest CP210x drivers and STM VCP drivers installed - I think the latter is a red herring because from what I read, the SPF3 lacks the capability, so it has to use CP210x.
What's different about INAV configurator?
Nov 11, 2017, 10:29 PM
P.I.Engineer's Avatar
I used to betaflight configurator to flag the inav firmware
Nov 12, 2017, 02:28 PM
Sorry - you mean you used the Betaflight configurator to *flash* the INAV firmware? I can actually flash the INAV firmware with the INAV configurator, by putting the board in bootloader mode - I just can't connect to it afterwards. I've just tried flashing an older NAZE32 board - same thing - I can flash and configure in Cleanflight and Betaflight, but can only flash in INAV by putting in bootloader mode and then can't connect afterwards.
Most frustrating.
Nov 14, 2017, 02:45 PM
P.I. Engineer - you're a star. I don't know how you arrived at the idea of using Betaflight to flash the INAV firmware, but I've just tried it and it works. I can connect without problem to the INAV configurator now, so this SPF3 clone doesn't need to meet Smashy the Hammer! Hooray!
Help! Cleanflight problem - Flashes but will not connect rtbcoop Multirotor Drone Electronics 5 Feb 09, 2018 08:18 PM
Question SPF3(cleanflight/betaflight) Using Aux to output PWM signal nitbeat Multirotor Drone Talk 15 Jul 16, 2017 04:52 PM
Help! Cant connect to betaflight or cleanflight to flash FlytHEHUNTER Multirotor Drone Electronics 2 Apr 29, 2017 01:40 PM
Discussion Flight controllers CC3D and NAZE 32 will not connect to Cleanflight or Betaflight wildwillie63 Multirotor Drone Electronics 8 Mar 06, 2017 11:18 AM
Discussion SPf3 mini crashing cleanflight. will not connect to sbus BAMAXXX Multirotor Drone Talk 0 Nov 22, 2016 05:26 PM
