Dremel Rotary Tool Accessories - RC Groups
This thread is privately moderated by RJ Reinhard, who may elect to delete unwanted replies.
Nov 10, 2017, 12:45 PM
Trader Rating: 53
Sold
Dremel Right Angle Attachment
for a Dremel Rotary Tool
The Dremel 575D Right Angle Attachment for Dremel Rotary Tool quickly and easily converts your Dremel Rotary Tool to a right angle tool. This accessory will enhance the versatility of your Dremel tools allowing you to get into hard-to-reach areas. The Quick connect system easily attaches to your rotary tool in place of the housing cap without the need of tools. The coupling system allows you to orient the right angle attachment on your tool in 12 different directions. Ball bearing and spiral bevel gears give long lasting durability along with smooth and cool operation.
Dremel Multipurpose Cutting Guide
The Multipurpose Cutting Guide allows for controlled cuts in a variety of materials including: wood, ceiling tiles, drywall, laminate, fiberglass, plastic and vinyl siding. The Cutting Guide allows for a sturdy controlled cut with maximum visibility and has depth adjustment.
Nov 10, 2017, 01:53 PM
Trader Rating: 58
Are these new and are the pictures showing the actual Dremel parts?
Nov 10, 2017, 04:14 PM
Trader Rating: 53
The pictures are of actual items for sale. The items are new condition since they have never been used. I no longer have a Dremel Rotary Tool so these accessories are not needed.
Nov 10, 2017, 10:56 PM
Trader Rating: 29
Rotary toll attachments!
Pm sent!
Sold 100pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 1 Oct 28, 2016 11:25 AM
Sold 100pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 0 Oct 23, 2016 01:58 PM
Sold 223pcs 1/8 Inch Shank Rotary Tool Accessories Bits Set for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 2 Oct 07, 2016 09:13 PM
Sold 150pcs Rotary Power Tool Accessory Bit Set Grinding Polishing Accessories for Dremel Mikey 68 Aircraft - General - Miscellaneous (FS/W) 0 Jun 10, 2016 04:10 PM
Sold Dremel flexible shaft Rotary Tool, Craftsman Rotary Tool, Harbor Frieght Rotary Tool. Mickey83 Aircraft - General - Miscellaneous (FS/W) 3 Jan 24, 2016 06:53 PM
