Loss of FPV Signal From 1ft Away - RC Groups
Nov 10, 2017, 12:36 PM
Please take some time to look over the information I have provided to help my fix this problem and get back in the air!
When I power on my quad and look into my video goggles, the picture has a lot of breakup. This is very odd as I am standing right next to the VTX and antenna. My goggles show a very inconsistent RSSI strength. The connection flickers from 100% signal strength to 20% very quickly.
Here is what I cam currently runnning for my FPV setup...
- FatShark Dominator HD3
- LaForge V2 (Version 2.1)
Receiving antennas
- 5.8 GHz SpiroNET Mini Patch Antenna (RHCP)
- VAS 5.8 GHz <ad Mushroom Antenna (RHCP)
- RunCam Swift Rotor Riot Edition
- TBS Unify Pro HV 5G8 - Race (SMA)
Transmitting antenna
-TBS Triumph 5.8GHz CP (SMA)
Attempted fixes
- Factory reset goggles and re-calibrated RSSI
- Changed VTX channel and band (viewed channel on both LaForge "spectate mode" and "manual mode")
- I have used different combinations of antennas and transmitters and received the same results
- Extracted FPV system from quad and set it up on a separate power distribution board. I achieved the same results using this method so I believe this rules out any interference from other components. I suppose this is a good time to mention that I have run this exact set up before without any problems sooo yeah
Nov 14, 2017, 02:01 AM
Master of Disaster
ChrisCro82's Avatar
Did you unlock your vtx?
It sorta sounds like your in pit mode.
Help! Loss of Video Signal From One Foot Away ZestyJalepeno FPV Equipment 7 Oct 01, 2017 06:45 PM
Discussion Furibee f36 fpv - signal loss on throttle Ddlaz FPV Equipment 6 Aug 20, 2017 04:20 PM
Help! Weird FPV Problem (intermittent loss of signal, cuts to static) jachjach FPV Talk 5 Aug 15, 2017 11:35 PM
Help! FPV Signal loss on 75% throttle jbroseann FPV Talk 16 Apr 30, 2017 04:01 PM
Discussion FPV with Spektrum DX6I & Orange R650X receiver signal loss Keihoop FPV Talk 0 Apr 04, 2016 01:24 PM
