Taranis x9e throttle fail safe - RC Groups
Nov 10, 2017, 01:12 PM
Taranis x9e below 0 throttle setting.
Im trying to setup fail safe on the throttle on an old eagle tree osd pro setup with ppm output using the v3 receiver and cant get the throttle to register below -1 on the osd setup screen. I setup a switch on the radio and it will go to -150 on the radio but only goes to -1 on the osd screen, not sure if its on the receiver side or the eagle tree , anyone have any clues.
Nov 20, 2017, 08:51 AM
JohnET's Avatar
Hello,
You will need to trim your throttle all the way down, set failsafe for the throttle channel in your radio to that position, trim your throttle back to normal and then re-run the RC Wizard.
Regards, John
Discussion Taranis X9D, L9R, NAZA V2, and fail safe Blckhaze Beginner Multirotor Drones 1 Jun 07, 2016 07:46 AM
Discussion FrSky X9E - Tray Radio - Taranis Rotozuk Radios 1245 Aug 20, 2015 01:21 PM
Help! Cannot get throttle fail safe to work gymcoach Beginner Multirotor Drones 3 Aug 20, 2015 10:40 AM
Discussion turnigy 9x firmware er9x-r811 throttle fail safe raffybuffy Multirotor Drone Electronics 1 May 07, 2014 05:08 AM
Question Throttle fail safe - how long is too long? pmackenzie Indoor Pattern/F3P 2 Mar 12, 2014 12:58 PM
