Nov 10, 2017, 11:41 AM
Question
Battery Checker
Does these Battery Capacity Checkers give a current change in battery and cell voltage if left plugged in while the battery is being discharged, or do you have to unplug and plug it in each time to get a current reading? Here is the link to one: https://www.motionrc.com/collections...ecker-balancer
Bob
Nov 10, 2017, 01:56 PM
RELAX. You'll live longer
785boats's Avatar
I have the Hyperion version, & I find that the numbers don't change as the pack is being discharged.
It needs to be unplugged & plugged back in to read the state of the pack.
Nov 11, 2017, 03:55 AM
you need to unplug and plug each time, no real time data
Nov 23, 2017, 06:46 AM
Been busy lately so it's taken me a while to say thanks for the replies. Have another question though. Is there a meter similar to this one that plugs into the balance plug that will give up to date cell voltage as it changes? I have a watt meter, but as you know it does not give individual cell voltage.
Thanks again,
Bob
Nov 23, 2017, 10:21 AM
My ISDT BC-8S will show real time fuel percentage. I just tested this by watching the voltage and percentage charge of my fatshark battery when I plugged it in and the googles put a load on it. If you need a video I can help you out with that as well.
Nov 23, 2017, 11:43 AM
pull up -- PULL UP!!!
Thanks again,
Bob
Do these in-flight cheapies do what you need?
https://www.ebay.com/itm/1S-8S-LiPo-...YAAOSw9IpXxOL3
They continuously sequence thru each cell voltage and then the total at about 1 second intervals. The alarm level can be set low or off.
Nov 24, 2017, 02:09 PM
J.Harris, thanks for the info. After watching a couple of videos I think the one you mentioned is just what I need.
Hard line, I have one of those, but it doesn't show all the cells at once.
Bob
Discussion Hyperion EOS Sentry 3 Battery Checker HyperionRocks Batteries and Chargers 39 Apr 07, 2018 06:52 PM
Discussion Using battery checker on 2S battery without balance connector espana23 Batteries and Chargers 13 Feb 21, 2017 11:15 PM
Help! Free Digital Battery Checker for Objective and Reliable Reviews on Amazon Ben Burns Batteries and Chargers 1 Jun 21, 2016 05:31 AM
Discussion Li-Po Battery Checker Not Working for 1S Battery? boba7523 Multirotor Drone Talk 15 May 09, 2014 01:43 PM
