Testing Multirotor motors and ESCs - RC Groups
Nov 10, 2017, 10:59 AM
I am used to taking my ESC, a battery, and a servo tester, connecting these up to a brushless motor, and testing it.
When I do this with a multirotor ESC (Afro 20A) and motor (Quanum BE1806) the motor stutters and jerks. It doesn't spin up.
Does this setup have to be run through a flight controller board to test?
Nov 10, 2017, 11:49 AM
Ace12GA's Avatar
Sounds like your ESC timing is off. Is that ESC running SimonK or BLHeli?
Nov 10, 2017, 02:48 PM
What voltage are you running your servo tester on? It probably needs 5V. The ESC should figure out that you are running PWM - I assume your servo tester is PWM.
Nov 10, 2017, 03:12 PM
servo tester is pulling voltage from ESC.
Nov 10, 2017, 03:43 PM
ESC probably needs separate power. I usually power ESC through lipo. And 5v to tester.
Nov 10, 2017, 04:35 PM
The ESC is plugged into the lipo and will provide power to the servo tester whether I add a battery to the tester or not. It's basically this exact setup:
Brushless Motor Test (1 min 20 sec)
Nov 10, 2017, 07:31 PM
Ok, I see. Your ESC have a BEC. This happened to me once. Make sure you have the servo tester turned all the way down. Let the ESC go through the boot sequence when you plug the lipo in. Then turn up the PWM.
Question Current limiter behavior during motor/esc test Blacky's Boy Beginner Multirotor Drones 3 Oct 23, 2016 08:44 PM
Discussion Little prop in slot to test small motor, battery esc combo Gregco10 Foamies (Scratchbuilt) 4 Aug 20, 2016 01:30 PM
Discussion Twin Brushless Airplane motors using Multirotor ESCs? 8thelephant Power Systems 2 Feb 15, 2016 05:07 AM
Video iPower MT1306 3100KV motors+15A mini ESC built in XpertDrone test iflightrc FPV Racing 0 Jan 06, 2016 04:40 AM
