1/96 LCT mk5 - RC Groups
Nov 10, 2017, 07:02 AM
20M northeast of Hell Mi
liljimmy's Avatar
Question
1/96 LCT mk5
I am in the process of building a 1/96 scale LCT mk5 to fit on top of my LST807 . The LCT will be 4inch x14.6inch ( just in the micro size limit).
My plans is to build a wood buck then vackuform the hulls.(Hull#1)I need to keep the weight down to a minimum to ride on top of the LST 807. (Hull#2)I thought it would be fun to R/C another one. The drive on the LCT had 3 props. In 1/96 the props are less than .5inch(i need to figure out the size). Has anyone attempted to do PE. then soldered to a shaft?
Thinking about drives..maybe 3 hacked servos with fixed rudders using the outboard drives as "tank steering" and the center for pushing
Latest blog entry: Blog
Nov 18, 2017, 05:46 PM
liljimmy's Avatar
The buck is complete
The .020 styrene sheet attached to frame
The vack box almost complete just need a piece of peg board from the big box store
Nov 25, 2017, 02:04 PM
liljimmy's Avatar
Installed the peg board on the vack box..before heating the plastic I gave this thing a " dry run" using a trash bag. A good thing I did, I heard a crack from under it now to get the top off and place some reinforcement inside
Nov 27, 2017, 04:36 AM
liljimmy's Avatar
Got 2 pulls yesterday . the first was to cold ,only 2 inch drop during heating
The second was too hot had 8+ inch drop and when moving the plastic over the parts I saw the wrinkle by then it was to late
I took the second pull then cut it out ( it won't go to waist) and will be used to figure out other build components needed. Weight just hull 25g
Nov 29, 2017, 10:42 AM
Big Boats Rule!
boater_dave's Avatar
If you can easily get some brass photo etch, sure, it's possible. You will need to bend each blade for pitch. In that small size perfection is not critical.
Or you can check Shapeways for a 3D printed prop. I saw several that might be candidates, in the 1/2"-ish size.
Or you can scavenge some props from those cheap fish tank boats.
Dave
Dec 07, 2017, 07:02 PM
liljimmy's Avatar
Attempted 2 pulls today, the first was a total disaster. It's a good thing I put tinfoil on the bottom rack.. the second was almost perfect one small wrinkle in the bow and one on the aft corner both are repairable. And I need to repair the buck before attempting to do another pull
Alert 1/96 - 1/100 Scale Fun Run May 20th-21th, 2017 hampboats Dock Talk 3 May 30, 2017 12:09 PM
Build Log 41" LCT Mk5 Barracuda RC Boats f15pilot Scale Boats 6 Jul 31, 2016 03:50 AM
Link Amazing 1:16 LCT Mk 6 French Build herrmill Scale Boats 5 Jun 18, 2012 03:18 PM
Discussion SSY 1/96 Alfa or Precision Patterns 1/96 Permit redboat219 Submarines 10 Sep 27, 2011 08:13 AM
Discussion 1/16 RC Centurion Mk5/1 oztruck RC Tanks 1 Jan 19, 2010 08:37 PM
