Nov 09, 2017, 10:22 PM
Betaflight F3 Won't Arm
I built a new 5 inch right before I moved. I got it unpacked and went to finish the config and it won't arm. I'm pasting the result of the status command below. It says the board is calibrating the sensors, but I let it sit for 10 mins and it still wouldn't arm. I'm out of ideas, maybe bad board?
# status
System Uptime: 689 seconds
Voltage: 111 * 0.1V (3S battery - OK)
CPU Clock=72MHz, GYRO=MPU6000, ACC=MPU6000
SD card: None inserted
Stack size: 2048, Stack address: 0x10002000
I2C Errors: 0, config size: 1996, max available config: 4096
CPU:17%, cycle time: 137, GYRO rate: 7299, RX rate: 110, System rate: 9
Arming disable flags: CALIB CLI
Nov 09, 2017, 10:56 PM
Just checked the sensor tab, and gyro doesn't move at all. 99% sure it's a bad board.
Help! BetaFlight F3 Board connects but won't go into boot loader mode? PFflyers Multirotor Drone Electronics 0 May 28, 2017 12:40 PM
Help! Betaflight F3 FC won't arm each time when the USB is not in. Mordicuss Multirotor Drone Electronics 11 May 17, 2017 12:06 PM
Help! Betaflight won't arm motors CanEHdian101 Multirotor Drone Electronics 2 May 04, 2017 06:06 AM
Discussion OMNIBUS FLIP32 F3 Won't Arm Glenfilthie Beginner Multirotor Drones 14 Nov 30, 2016 06:20 PM
Discussion BlHeli ESC's won't do the second beep, motors aren't arming whisker FPV Racing 1 Apr 11, 2016 04:33 PM
