Questions about imax b6 operation - RC Groups
Nov 09, 2017, 05:24 PM
WildDoktor's Avatar
I have a genuine skyrc imax b6 charger. It comes with a 12v (5a, I think) power brick, connectors, and the wifi dongle.
First question: Can I charge 1s HV packs to 4.35v? If so, how?
It seems I can only set the charge voltage to 4.30v. Do I simply need a bigger power supply? Or is that a hard-stop in the imax itself?
2nd question: should I be able to set the imax to 4.2v and expect a single battery or a set of 4 batteries in parallel to end up being charged to 4.2v?
I made my own parallel harness, and also now have a crazepony parallel board. (No need to discuss the pros/cons of parallel vs serial; let's just pretend that parallel is the way I want to go for now. :-) ) So far I charge 4x 1s gumstick whoop batteries at a time.
But in the above scenario, the batteries always end up only charged to between 4.0v and 4.12v (whether I'm charging 1 or 4). If I crank up the voltage on the charger to 4.25v, then I can get the batteries up to 4.2v, but it takes much, much longer to get that extra .08 to .2v. Am I doing something wrong?
3rd question: Will somebody who uses this particular charger regularly to parallel charge 1s gumstick batteries to 4.2v please upload some screenshots of the settings you use? Also, if you're using this charger to charge 1s HV batteries to 4.35v, please upload some screenshots of how you're doing it.
Thanks!
Nov 10, 2017, 06:44 AM
User Registered
RustyUs's Avatar
If you have the B6AC V2 you can do LiHV cells.
Nov 10, 2017, 07:43 AM
a LiHv can not be charge to full voltage with this charger it does not support LiHv.... a 1c charge should be complete on a lihv charger in a hour..
since this has a power brick a external power supply it is not a imax b6ac v2
Nov 11, 2017, 04:57 AM
B6 can not charge 4.35V battery
Nov 11, 2017, 09:06 AM
My B6 only knows 4.20V for Lipo charging.
Nov 11, 2017, 02:55 PM
WildDoktor's Avatar
Thanks for the responses so far guys! Yeah, I don't have the b6 v2, so no HV. However, I do have the wifi dongle and in the app I can go up to 4.3v...and my batteries end up at 4.26v.
So, any takers on my 2nd question: should I be able to set the imax to 4.2v and expect a single battery or a set of 4 batteries in parallel to end up being charged to 4.2v?
My batteries never end up at the voltage that I set the charger to. Any idea why?
Discussion IMAX B6 Question CFLFPVME Batteries and Chargers 8 May 18, 2017 11:14 PM
Question NiMH and IMAX B6 question. LifeofBrian Batteries and Chargers 1 Jan 23, 2017 04:02 PM
Help! New Imax B6 Mini (original) question... richr69 Batteries and Chargers 1 Jan 29, 2016 11:25 AM
Discussion Imax B6 connector question toxicdude Batteries and Chargers 1 Dec 05, 2015 08:21 PM
Discussion Question about iMax B6 multi-lipo charger with board kctenboom Batteries and Chargers 5 Apr 01, 2014 11:30 PM
