Nov 09, 2017, 04:59 PM
flying quadkart 200kilos
I wanted to build a somewhat affordably quad go kart for flying over water at low altitudes.. I weigh 97 kilos and would guess the frame with electronics and lipos would be another 100 kilos.
who makes a motor and prop that could give me 3:1 power to weight ratio?
Nov 10, 2017, 02:30 AM
Better look for a hovercraft, what you envision will give you at most 15 min of flight, if approaching as electric propulsion, which not worth the effort.
Hovercraft give you same feeling as flying at low altitude and don't sink when a motor stop
Nov 10, 2017, 10:33 AM
Somewhat affordable and 97 K payload I think are mutually exclusive. Also a quad would need really large props and and fall out of the sky with a single rotor failure. I have seen several designs that can lift a person. They all had many more than 4 rotors. They did not fly for very long and I am sure they were very expensive.
Here are a couple:
Casey Neistat
HUMAN FLYING DRONE (4 min 13 sec)
Ferdinand (EndOfDays)
(2 min 53 sec)
Woman flying on a drone
Electric Airboard Flight! Drone footage by 904Aerials (3 min 21 sec)
Nov 10, 2017, 12:22 PM
I was thinking along the line about gasoline generator running wot, to keep the juice flowing, and use a small battery pack as a powered buffer for flight.
Nov 10, 2017, 12:40 PM
Nov 10, 2017, 02:41 PM
géry 46's Avatar
Mariah Cain Training on the MegaDrone (3 min 39 sec)
géry 46's Avatar
Canadian Develops Futuristic Hovercraft (7 min 48 sec)
Nov 10, 2017, 02:42 PM
géry 46's Avatar
THIS IS THE US MILITARY HOVERBIKE PROTOTYPE (2 min 19 sec)
Nov 11, 2017, 12:06 PM
anyone got a source for motors and props, I want to stick with 4 motors for simplicity . I want to layout a single seated configuration
Nov 11, 2017, 04:02 PM
You want to build (and ride !) this without a minimal understanding ... ?
For example the first logical question I would ask is how to compute the propulsion required for such task... then start search for the motors that do the job.
Surely aren't the kind of motors sold at HK
Nov 11, 2017, 04:30 PM
ok,
AUW of 400lbs, so we're at 100lbs per motor, double that for 2:1 power : wieght , so i need 200lbs of thrust
generator output at 220 volts AC
from http://www.godolloairport.hu/calc/strc_eng/index.htm i get.....
Prop size : 69 inches diameter with 41 inches of pitch= 243 lbs. of thrust 110 Kg,
Power: 50 HP , 37kW X 4= 200HP generator , lol
prop rpm : 2000
Motor kV: ?
ESC: ?
Nov 11, 2017, 04:47 PM
I think the generator idea is off the list, next option would be small 2 stroke air cooled motors
Nov 14, 2017, 01:07 PM
géry 46's Avatar
chAIR -Manned quadcopter Open space flight Episode 27 (5 min 28 sec)
Manned multirotor Part 20 -First Flight! (25 min 51 sec)
1 MAN Skycar (2 min 37 sec)
2012 WASP project (17 min 1 sec)
Williams WASP BBC The Century of Flight exerpt (0 min 31 sec)
Flying Machine Real .mp4 (1 min 32 sec)
Martin Jetpack - Military & Commercial Applications [480p] (3 min 34 sec)
Martin Aircraft Completes Latest Phase of Manned Test Flying (2 min 55 sec)
Nov 16, 2017, 10:32 AM
but will they support 400lbs for 30minutes
i do like the flying trashcan, good find!
Nov 17, 2017, 01:02 PM
géry 46's Avatar
celier-aviation-fanman-550e...
http://www.pyperpote.tonsite.biz/lis...on-fanman-550e
Discussion Griffin, GA R/C Field The old Flying Griffins Flying Site For Sale Sukhoikid Club Talk 0 Aug 21, 2017 03:34 PM
Discussion Has your flying field banned FPV flying? Zé Povinho Electric Plane Talk 138 Apr 08, 2016 09:47 PM
Question Who is Flying Saturday Night and what are you Flying? Michael Heer Arizona Electric Festival 2016 8 Feb 24, 2016 08:52 PM
