Nov 09, 2017, 02:59 PM
You down with EPP?
johnnyrocco123's Avatar
Help!
3D 30cc airframe 68" - 72" ?
I have a setup I am looking for a home for.
Its a Motrolfly 4325-380kv
19x10 prop
6s 5000mah.
Problem is, there doesn't seem to be a good 3D airframe to fit this any longer???
It was the go to for the 71" Slick, and a great match for the 70" Slick Pro from Aerobeez, but neither are available.
The bigger the better, I would hate to weigh down a 64" model with big batts.
Any help would be greatly appreciated.
Nov 09, 2017, 09:40 PM
100% electric since 1990
twest's Avatar
Aj ars 300 67”
Nov 09, 2017, 10:01 PM
You down with EPP?
Originally Posted by twest
Aj ars 300 67
Yeah, that's what I was looking at. Looking for weight, i hear it's heavy.
Nov 09, 2017, 10:22 PM
It is. From what Ive read its within a pound or so of the new EF 74 Slick running a 12s setup. I believe you were able to do a 6s 5000 setup on the older 3DHS 74 Edge so Im betting you could do the same on the new lighter 74 EF planes like the Slick.
Nov 09, 2017, 10:42 PM
Dennis C's Avatar
Should work on any of the 70+ 10-11 lb airplanes Not as good as the 12s systems but as good as it was then in the 70 inch Slick.
Slick, Extra or Edge Get one specific for electric
Dennis
Nov 10, 2017, 11:48 AM
Dennis
I have a 6s Motrolfly 4330 380kv 22x10 Xoar PJN setup on my AJ Laser 73. It works great - the plane weighs around 10.5 lbs and has around 2500w of power. Not a rocket but more than enough for me.
The EF Slick 74" could be assembled with a similar setup and from what I have read would weigh the same or maybe a bit less.
I don't have experience with the ARS 67" but reports I have read definitely suggest it is heavy. I sold my ARS 83" after about a dozen flights on it because it was very overweight despite my best efforts to keep it light.
Nov 10, 2017, 01:59 PM
You down with EPP?
What battery are you using? mah?
Nov 10, 2017, 03:59 PM
Keep in mind Malcolm's motor is listed as a 4330 and the other is a 4325. 4330 is a bit bigger.
Nov 10, 2017, 07:37 PM
You down with EPP?
I picked up on that.
Discussion Seesii Vision-720S 68" FPV Goggles 3D Video Glasses 5.8G 40CH Receiver Manchild FPV Equipment 0 Nov 24, 2016 12:37 AM
Help! Mostly foam constructed 30cc gas airframe? georgy Fuel Plane Talk 17 Jan 25, 2014 12:14 AM
Discussion A 3D airframe for a Turnigy 30cc gas asimmetrico 3D / Fun Fly Fuel Planes 16 Oct 03, 2013 10:26 AM
Help! Wanted 30cc airframe ian.c United Kingdom 0 Dec 21, 2012 06:27 PM
Question Looking for 3D airframe and 30cc gas engine recommendation Xnaron 3D / Fun Fly Fuel Planes 11 Oct 21, 2012 03:34 PM
