Brittish island class offshore fisheries cutter - RC Groups
This thread is privately moderated by tc432, who may elect to delete unwanted replies.
Nov 09, 2017, 02:34 PM
Trader Rating: 13
$225.00 USD
Buyer pays shipping
Sold
Brittish island class cutter. 1/48 scale 50x9. Partially completed with steering servo. Brass prop ,shaft installed. Some fittings. Brass railings and piano wire included. Built on the fiberglass dynamic sea-going tug hull. Was a great running ship with a very stable displacement hull. Could also be built into the Steve Irwin whale wars ship. Has great interior access.
Nov 13, 2017, 07:02 PM
Trader Rating: 4
I am curious as to what your plans were to finish this ship. I am not an experienced boat builder. What motor / ESC did you plan to use? I spent sometime looking at British Island class cutters. Most of the images are of USGG models, not the earlier British made ones. Clearly yours does not look to be based upon USCG... Not that I am looking for an award winning replica, beyond my skill level. But if I can pick up where you left off, I might get a good looking ship.
Nov 13, 2017, 08:21 PM
Trader Rating: 13
Offshore fisheries protection vessel
This model is the brittish island class used I believe in the1970s-1980s to patrol the North Atlantic during the cod fisheries war with Iceland. One of these vessels was sold to green peace and became the Steve Irwin. Below are some photos to show what the real ship looked like and what I intended to finish it as.
Nov 13, 2017, 08:26 PM
Trader Rating: 13
Ship
Some more photos
Nov 13, 2017, 08:35 PM
Trader Rating: 13
A geared 12 volt motor say 3:1 gear ratio would work well. A 7amp hour 12 volt battery and any compatible esc.should work well with this model. This model has about a 16 lb displacement. So it is a vary solid stable running ship. I did run it a few times and liked the way it handled. Tom
Nov 14, 2017, 07:15 PM
Trader Rating: 4
I am still looking at the boat real hard, like what I see…
Little trouble selecting a motor. I haven’t found a 12V with a 3:1 gear ratio. However, Harbor Motors has something close.
https://www.harbormodels.com/motors.html
Under the “500 Geared Motors” they have two good possibilities. The MFA16 has a 2:51 gear ratio, different rpm output based upon voltage. The MFA7 has a similar rpm output at 12V when compared to the MFA16 at 6V. That motor is 6:1. Any idea what rpm range you had? Can you make a recommendation here?
When you ran the boat, did you add additional ballast?
Nov 14, 2017, 07:25 PM
Trader Rating: 4
Any idea what shipping would cost to 80232, insured?
Nov 14, 2017, 09:48 PM
Trader Rating: 13
Fly guy, I’ll pm you tommorow with shipping est and thoughts on the motor.
Nov 14, 2017, 09:52 PM
Trader Rating: 13
3:1 Mack drives would work. I had tried a 12 volt Pittman 3600 motor and that was direct drive at about 3600 rpms and it worked great. These motors are hard to come by now. A dumas 12v geared would work.
Nov 16, 2017, 12:31 AM
Trader Rating: 1
Check your inbox messages.
Build Log USCGC 1313 Edisto, 110 ft Island class cutter DDG 51 Scale Boats 89 Apr 27, 2017 04:05 PM
For Sale 1/48 scale Hms Guernsey offshore fisheries protection vessel tc432 Boats (FS/W) 3 Dec 06, 2015 11:18 AM
Sold Imex Island Class Coast Guard Cutter. PSV Captain Boats (FS/W) 7 Apr 01, 2010 09:02 PM
Discussion Imex Island class cutter refit.\ PSV Captain Scale Boats 5 Mar 19, 2010 07:12 PM
