Some initial details in the cockpit
Elevator made and in place
The full airframe so far
It's time to loose some hair with the windshield.
Jezus, how to shape such a small piece of thin aluminium? |
Obviouslly i wouldn't let the brushless motor in the nose without a dummy engine covering it...
Once again, coming from the 3D project to the real world i casted some polyester resin inside a tube and used it to machine the cylinders and the engine body. The dummy motor will be splited in two parts. The back part (backplate) will be used to mount the brushless motor and also will be screwed to the firewall, then, the front part of the dummy engine will cover it all and be kept in place just by press fit on the back plate. |
It's landing gear time...
Before covering the fuselage i had to ensure everything was as it should be and made a quick test on the servos and tail linkage.
QA Passed!
Every fabricated part so far
Fuselage covered and painting started....
ImagesView all Images in thread
Now things start to get insteresting...
It's time to start detailing it as much as possible. So many ultra small parts, really very hard to work with... Here i made the first 3 instruments: Oil pulsator, oil pressure, and compass |
Moving on to throttle lever and that kind of box that i don't know the name
Here it's possible to see the fuselage already aged and wetheared...
Some more details done like pull pull cables exit, throtle lever painted and in place, etc.. ImagesView all Images in thread |
Holy cow, that's some fine work! Are all those scale details hand-fabricated? My 3D printer is jealous!
I love the gauge in front of the cockpit (compass?). Regarding old LiPos - if stored properly (3.7 - 3.8v at modest temperatures), they can last an amazingly long time. I routinely fly with 5000mah packs that sat unused from 2007 until last year (I would be doing that right now on my Kaos 60 but the dang park where my club field is closes early now ). I also have plenty of other smaller packs and single cells of a similar vintage. I keep a closer eye on them that newer packs, but they are still going strong. One key - I rarely discharge any of my packs above 15C. Mike C. |
Thread Tools | |
Similar Threads | |||||
Build Log | Fokker E III Eindecker, Peter Rake design. WS 60" | bth | Scale Kit/Scratch Built | 33 | May 22, 2023 10:03 AM |
Discussion | Fokker E.III Eindecker - Laser Cut Balsa Kit 1520mm (60") | Secretsenor | Electric Warbirds | 3 | Aug 28, 2019 03:16 AM |
Discussion | 1/6.5 Fokker E.III Eindecker | Mfight43 | Scale Fuel Planes | 5 | Jun 16, 2017 07:10 PM |
Build Log | Fokker E III, scale:1/6,5 WS=153 cm | bth | Scale Kit/Scratch Built | 19 | Jan 30, 2016 09:01 AM |
Discussion | Hobby Lobby Fokker E.III Eindecker | chuckrip1 | Electric Plane Talk | 6 | Mar 11, 2009 09:07 PM |
