He 162 B (C or D?) - RC Groups
Nov 09, 2017, 12:28 PM
Bare's Avatar
He 162 B (C or D?)
Begining on a small 162 B 1;12 scale 24" span, 120 squares so weights need watching and imo a bit small for wheels.
Yess these were tiny machines.
Either formed Balsa shells or Lost foam as planned fuse/pod construction.. could be tricky though.. will find out
Unsure as to a B ' the production version' or the on paper swept wing, v tail paper derivatives
Likely the B version.. No biggie as fuses are similar.
Lots! of info on He162's,. too much almost... 3 views , as always, differ from each other.. no news there but always amazes .
Settled on my Tamiya 1:48 kit images as the most reliable .. attached pdfs (100% print scale gives an accurate 1:48 print)
Nov 09, 2017, 01:39 PM
Oh no, not again!
jhspring's Avatar
You build cool stuff, Bare, but at 24" span, I'd have to stick to a plastic model. I'm having to go to 50-60" to compensate for old eyes and slowing reflexes. Scale it up, 250% or so and we're talking.
Actually, I am amazed at the scale detail you manage to cram into your mini-models. Always something to learn.
Regards,
Jeff
Nov 09, 2017, 03:51 PM
I may be some time ....
balticS2's Avatar
On those little wings it's going to go like stink. You could do them a little over scale and we won't tell.
4oz glass / 1/16 balsa / 1oz glass laid up over a plug might be another possibility for the shells.
What are you thinking to power it. At 24" span, I'm thinking the fuse and pod dimensions won't he too restrictive.
Alec
Nov 09, 2017, 04:24 PM
Oh no, not again!
jhspring's Avatar
Alec
Heck, Alec, at 24" he could vac-form everything and use balsa spars and formers. As much detail as you care to put into your plugs for no weight.
Regards,
Jeff
Nov 09, 2017, 04:37 PM
P_J_Glor's Avatar
Propulsion? 30mm size ducted fan?
Enquiring Minds want to know . . .
Pete G
Nov 09, 2017, 05:21 PM
Bare's Avatar
Actually Bigger than it reads .
The size looks to just fit on My coffee table.. surprised me too. The Numbers mislead.
Power: Likely the HK Ali 40mm unit ~15 oz thrust and 5 oz coupled to a usable battery, ~2 oz avionics, ~8 oz airframe = 1:1 thrust possibilities
30mm will of course fit. Light and simple. But it's ~5 oz thrust and frankly it looks like a thimble as placed on the drawings. Disconcertingly tiny tbh.
Still? If I can build a decent looking airframe... light enough... I will try it
Astute of you Jeff
I'm considering that as well, nose , inlet and tail cones will be vacu formed regardless. Likely have need for a few spares as well.
Vacu forming does require a durable wooden plug. Foam ones tend to distort.. quickly. Unfortunately wood is bit more work to carve than foam.
Formed balsa on a plug shell is similar to a Vacuformed shell.. just more fragile.
Read somewhere that innovation/invention is the result of lazy people looking for an easier way. Credible when thought about
Again; new to me territory.
Nov 09, 2017, 06:47 PM
balticS2's Avatar
OK. Back of fag-packet calc suggests its considerably shorter and slimmer than I imagined - fuselage about 30.5" long and up to 3,5" wide. So composite possibly overkill. Looks like you could go to about 45mm on the fan and have scale inlet and outlet.
Nice having the fan in the pod. leaves you with much more flexibility in the fuse.
Dental plaster for vacuform plugs?
Whatever. Looking forward to watching you do your stuff
Nov 10, 2017, 02:05 AM
Res Ipsa Aviatur
Longhorne's Avatar
Great subject, Bare.
Just brushed up on Wikipedia. I didn't realize that the 162 saw quite a bit of combat. Three pilots resorted to that early ejection seat, too. Two survived.
Paul
Nov 10, 2017, 10:15 AM
jumo004's Avatar
... erm ... I don't know your flying skills but with a 19.7 WCL they must be exceptional ....
Nov 10, 2017, 01:35 PM
Fly, dangit!!!
Led Zepplin's Avatar
Interesting subject, always liked the He162. I always thought it’d be cool to see the forward swept wing version with the V tail (whichever letter version that on is). I don’t think it was ever actually built, but it is the most interesting version in my opinion! I think that one has more wing area too which might help you some.
Nov 17, 2017, 06:12 PM
Bare's Avatar
Two steps forward, one step back.
Decided (may live to regret this) to try Two scales
1:24 at 24" wing span for 40 mm HK/rc lander fan unit
~1:15 at 20" ws for QX 30 mm fan gizmo.. simple curiosity as to how this fan will work..as iffy excuse
Both allow for exact scale inlets at their scales.
Photo of fans on their respective blowups attached.
Blu Foam blocks cut and waiting, in final stages of making templates to wire cut the basic outlines.. for Both versions
Nov 18, 2017, 10:48 AM
Oh no, not again!
jhspring's Avatar
er, uh how is 1/15 smaller than 1/24? 1/32 maybe? Definitely plastic model scale.
Regards,
Jeff
Nov 18, 2017, 11:38 AM
balticS2's Avatar
I hadn't thought it advisable to ask that Jeff
Nov 18, 2017, 02:08 PM
Bare's Avatar
Ooops ...Dyslexia in action!
It's 1:12 scale rather than what I mistakenly typed.
What 's unsaid is the surprising , to me at least, size differences betwixt 1:12 and 1:15, for such a small numerical difference in the ratio.
Nov 22, 2017, 06:46 PM
Bare's Avatar
One plug ready.. one to go
As above , Blu Foam plug made for 1:15 scale version. Photo'd with templates... weighs 44 gms as is .. tempting to simply 'finish' the Foam.
Tried the Flitetest suggestion of Ali taping the Foam core template edges for durability (I used Graphics arts store quality 1/8" foam core, hey! 6$ for a 4' x 4' ..,in fairness though the suggestion was intended for $ store junk, which actually costs more
Quick answer is ; Don't!
It heat sinks the cut wire.. messing the cut.. and the foam in the decent foamcore used wasn't affected by the wire heat.. at all.
Tomorrow I will wire cut the 1:12th fuse then ugh... sand it.
Dryer sheets (antistatic) Do help with the foam snow problem though. Good thing I got a large box of them.
A couple of techniques in mind to building a fuse to follow. Inset ring formers into the fuse plugs, then Planking the things or Ammonia forming Balsa half shells.
Thinking it might be clever to ammonia form formers into rebates.. on Both tries ..balsa half shells will need support as well.
Wings, tail bits seem as a Doddle to assemble at this point. Fuse and engine pod is where the build effort centres... in this design
Imo too small to worry about stick 'n film wing constructions weight advantages .. besides, I don't like the look of that as imitation of a solid surface.
So simple balsa ribs and sheeting will do Nicely, also useful in cartwheel arrivals.
Discussion Scratch Built Heinkel HE 162 EDF setup help MiZer1981 Electric Ducted Fan Jet Talk 19 Nov 25, 2016 01:55 PM
Discussion Midwest HE-162 jrrozz Fuel Jet Talk 7 Sep 23, 2016 07:10 PM
Discussion He 162 starmax Silvertoy Scale ARF/RTF 0 Jul 29, 2016 05:14 PM
Scratch Built He-162 R&D The Max-Q Electric Ducted Fan Jet Talk 6 Nov 09, 2005 10:46 AM
Which would be a better first EDF, He-162 or A-10? C. Alan Electric Ducted Fan Jet Talk 2 Sep 20, 2004 12:52 AM
