This thread is privately moderated by 2dogrc, who may elect to delete unwanted replies.
Nov 09, 2017, 07:35 AM
Trader Rating: 62
"woof"
$19.99 USD
Buyer pays shipping
For Sale
IFlight Force Stackable Switchable VTX 25-600 mW
This is a stackable, variable power VTX that can be powered by up to 24V! We are marking these down because the Tramp Protocol did not work on this batch, so you have to use the easy to reach push button.
Marked Down to $19.99, plus $7.50 Priority Mail or $4.00 first class mail.
Also available here: 2dogrc.com
This VTX is easily stackable under your FC. This now includes the Tramp Protocol allowing you to change the power and channel via the Betaflight OSD. You get 2 antenna extensions, 1 linear and light weight, the other is SMA. Also check the MMCX connector. This is much stronger then many other connector types on the market!
- The output power is stable ,the far transmission distance:≥0.5km@25mW, ≥1km@200mW, ≥2km@600mW;
- Transmit power 6 gear switch: 0mW/25mW/100mW/200mW/400mW/600mW;
- Output 48 frequency points, and has E group 8 race frequency at the same time using each other without interference;
- Frequency lock fast, boot does not interfere with companions;
- Built-in output power self-check function;
- Full format video format:NTSC /PAL;
- Wide input voltage range. low power consumption; 7V~24V,+12V/260mA@600mW;
- Small volume: 36mm×36mm×5mm;mounting holes correspond exactly CC3D NAZE32 F3 F4 Flying control
- Light weight: ≤6g(Does not contain antenna)
New Product Diatone SP3 Stackable Switchable 25/200/600mW VTx /w OSD, Pigtail, & 5V BEC - $40 lmpuIse FPV Equipment 146 May 25, 2018 04:05 PM
Sold HGLRC 20mm stackable XJB TX20 Mini 5.8G 72CH 0/25mW/100mW/250mW Switchable FPV vtx TurKFX FPV Equipment (FS/W) 1 Oct 26, 2017 10:03 AM
Sold HGLRC 20mm stackable XJB TX20 Mini 5.8G 72CH 0/25mW/100mW/250mW Switchable FPV vtx TurKFX FPV Equipment (FS/W) 0 Oct 20, 2017 01:39 PM
Sold Foxeer TM25 Switcher VTX - 25/200/600 mw ScudRnr Aircraft - Electric - Multirotor (FS/W) 1 May 19, 2017 09:10 AM
New Product GB - 130 Bundle with EMAX RS1306/4000KV, RunCam Swift, F3 FC, 25/600 mW switch VTX snappyhh Micro Multirotor Drones 2 Nov 03, 2016 03:03 PM
