Nov 09, 2017, 04:58 AM
Help!
Naze32 afroflight WONT connect
My Naze32 afroflight wont connect to betaflight/cleanflight.
The Driver is installed and visible, but when I try to connect it says “ this firmware version is not supported, please upgrade to firmware that supports a.p.i version 1.2.1 or higher”
Can anyone help please!
Nov 09, 2017, 05:05 AM
Naze32
Sometimes the Naze32 wont even connect to betaflight/cleanflight.
It says no configuration received within 10seconds, communication failed”
Nov 09, 2017, 08:18 AM
Team AlienWarpSquad
That's a new error message for me.
Sounds like the Firmware in your Naze32 is very old.
Try using the Terminal program (hyperTerm, Putty, etc) method as described in the Naze32 Manual to get into the CLI and check Vesion. Then the STM loader utility as per the naze manual to flash newer firmware.
Dec 14, 2017, 09:16 PM
I have the same problem. Not sure if I even have a Naze32 Board. was suppose to be. any help would be appreciated.
Dec 15, 2017, 12:32 AM
https://github.com/cleanflight/clean...rator/releases
https://crx.dam.io/ext/kdaghagfopacd...cocjccjao.html
Find a older version that works ...
If you don't know how to install a older CF or BF there are youtube tutorials
Dec 15, 2017, 08:25 AM
My quadcopter is not a drone!
unseen's Avatar
You have an "SP Racing F3". (A clone thereof.)
It's printed quite clearly on the board.
Dec 16, 2017, 02:27 PM
You got a firmware /configurator mismatch. Either update firmware or find the correct configurator.
Dec 18, 2017, 12:52 PM
Knowing its a spf3. it was baud rate fixed the problem. TY all
Help! Another Naze32 problem.. Cleanflight wont connect LukesGFX Beginner Multirotor Drones 29 Nov 10, 2018 08:54 AM
Mini-HowTo Afroflight Naze32 Setup Guide For Dummies, like myself. sdueck Multirotor Drone Electronics 11533 Jun 14, 2018 01:00 PM
Help! Naze32 Rev6 Afroflight FC won't connect to Clean Flight chrish97 Multirotor Drone Electronics 0 Jan 14, 2017 02:07 PM
Help! Naze32 wont arm unless connected to PC (solved) now drifts in hover cale10 Multirotor Drone Electronics 6 Aug 19, 2016 08:14 PM
Help! Naze32 Rev6 AfroFlight wont arm yaoweic Multirotor Drone Electronics 12 Jul 28, 2016 04:14 AM
